Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > First Generation Legend -- 1986 - 1990 > 1st Gen. Legend Performance Enhancements
Old 06-10-2009, 09:01 PM   #1
Default Auto to Manual Swap
Originally Posted by Legend_Master
ok so I am going to do the swap on my legend and I have taken your list and made it a little eaisier to read and fallow let me know if I have left anything out or messed anything up.
Items Needed
5 Speed Tranny
Transmission Mounts
Intermediate Shaft
Clutch Pedal and gas brake pedal
Manual Flywheel
Clutch
Front Motor Mount Brackets 2 Pieces
Starter Bolts
Flywheel and clutch bolts
Throw out bearing
Master and slave cylinders
Clutch damper hoses
5 of wire
Shift linkage
knob and boot
Neutral Safety switch
1. Wire the thick (black with white stripes) wires together
2. Cut the wires that are going to the S3/S4 switch and cap them
Shift Lock Solenoid
1. Cut the wires for the shift lock solenoid and cap them (this allows the vehicle to start normally with the clutch in and for cruise control to work
2. Now remove the bottom plastic panel from the steering column and cut and cap the wires going to the ignition switch solenoid that prevents the key form being removed while the car is in any other gear except park. MAKE SURE TO CUT THE RIGHT WIRES!!!!
Reverse Switch.
1. Send the (Yellow and Green with black stripes) wires to the reverse switch
2. Take the reverse switch apart and located inside will be 6 small metal contacts with another longer metal contact that is the length of 3 or 4 small contact.
3. The longer contact is connected to a black wire; connect this to the green wire that is across from it when looking at the contact. (Cut the rest of the wire and cap them)
Old 07-29-2009, 08:40 PM   #2
Ken
ridin' high
Ken's Avatar
Send a message via AIM to Ken
Does anybody know if the front mount is different? I know the front mount bracket is, but just wondering. Also, is the mount different? I heard on somewhere here that it is.
. k e n
Old 07-29-2009, 11:33 PM   #3
I know the rear is since I got a rear motor mount for a MT.
Old 07-29-2009, 11:45 PM   #4
Ken
ridin' high
Ken's Avatar
I see, so the rear mount is different and the front mount bracket it different.
. k e n
Old 07-30-2009, 08:30 AM   #5
Ken, the rear mount has a different part number between AT and MT...
I got my rear mount from either Rock Auto or Imported Car Parts I forget (because one site had only the front and the other the rear)...but ICPs asked whether I had a MT or AT upfront before looking at the mounts so I'm sure its a significant difference if the aftermarket has different ones as well...
Here's Delray's stuff:
Manual:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Auto:
I just choose a MT as my car and Delray automatically filters out anything that the auto would use...I bought side, front, and rear mounts, the Insulator (called the Wind Stopper), and the rebound stopper (just in case it's needed...it was cheap enough)...
Old 08-07-2009, 06:30 PM   #6
Ken
ridin' high
Ken's Avatar
anybody know if 2.5 and 2.7 flywheels the same for sure? I checked acuraoemparts.com and it lists the same parts numbers.
. k e n
Old 08-07-2009, 09:16 PM   #7
Yeah they should be...especially if their database is giving you the same #...
Old 08-07-2009, 11:33 PM   #8
telafonic
telafonic's Avatar
telafonic will become famous soon enough
Gabe, I've got a tranny I'm willing to donate, it needs attention though. Unfortunately I don't have any of the other items you need, but feel free to ask me any questions, I still remember a few things about how I did it.
telafonic is offline   Reply With Quote
Old 08-08-2009, 09:56 PM   #9
Ken
ridin' high
Ken's Avatar
I pulled the intermediate shaft today off a 90 5-speed coupe and it looks identical to my 87 base model's
. k e n
Old 08-11-2009, 09:33 AM   #10
Willie1980
new here..not 2 life
Willie1980 is on a distinguished road
I was wondering if anyone knew what years and models I could scoop the manual transmission out of to enter into an automatic 90 Legend.
Thanks.
Cam
Willie1980 is offline   Reply With Quote
