Old 06-06-2009, 02:39 PM   #1
Default TCU Codes and What They Mean
Originally Posted by Murderotica
Enjoy!
TCU Location
The transmission control unit is located under the drvier's seat and it faces forward, toward the engine compartment (and your feet).
The transmission CPU is the form of an aluminum box (With a black plastic cover) with a little plexiglass window. All you have to observe is a little red LED in that window.
Extracting Codes
With the key in the first position (on), observe the blinking of the red LED in the window. When you first turn the key to this position, the TCU will give one long flash to indicate it is functioning properly. The light will then blink, displaying all the codes in sequence and then repeating them in the same order.
Reading Codes
The code numbers are read by counting the number of blinks between each long pause. The code number is indicacted by a series of fast LED blinks and then a longer pause. If there are multiple codes, it will display them in numerical order, starting with the lowest code, then a longer pause and then the next code.
TCU Reset
Sometimes it may be useful to reset the memory of your TCU. Although that is most often done by removing the negative terminal from your battery for a few moments, it will also reset your clock and radio/stereo presets. A better (and less well-known) way to reset your TCU is to remove the alternator fuse for about twenty seconds.
TCU Codes
1 Lock-up solenoid 'A' circuit open or shorted.
2 Lock-up solenoid 'B' circuit open or shorted.
3 Throttle Position Sensor circuit open or shorted.
4 Vehicle Speed Sensor open or shorted - No signal from speedometer.
5 Shift Lever Position Switch circuit shorted.
6 Shift Lever Position Switch circuit open.
7 Shift Solenoid 'A' circuit open or shorted.
8 Shift Solenoid 'B' circuit open or shorted.
9 Counter shaft or transmission speed pulse generator open or shorted.
10 Coolant Temperature Sensor open or shorted.
11 Engine RPM ( Ignition coil signal) open or shorted.
13 Main shaft speed pulse generator open or shorted.
14 Linear (line pressure control) solenoid open or shorted.
15 Kickdown switch circuit shorted.
Old 06-06-2009, 02:41 PM   #2
Also remember, if you have and 86-87 sedan with the 2.5 engine you will not have a TCU...
Old 10-23-2009, 07:03 AM   #3
18 characters long
SquareBobPantsSponge
18 characters long's Avatar
Real Name: Dawson
Send a message via AIM to 18 characters long Send a message via MSN to 18 characters long Send a message via Yahoo to 18 characters long Send a message via Skype™ to 18 characters long
WTF is a code 12? It just popped up on my '90 TCU... there is no code 12 on here.
Fut
