Old 06-03-2009, 10:14 AM   #1
Default Painting Brake Calipers w/o Removal
Hey guys here it is!! This is the DIY for painting your brake calipers without removal.
Removal is always best, but this works too!
This is an easy one guys…
Here are the materials needed:
~Large can of Brake Cleaner
~Engine 500 paint (500 degree engine paint will definitely survive the high temperatures created by the calipers)
~Wire brush
~Oil/catch pan
~Masking Tape
~Newspapers
STEP 1
Of course you need to raise the car up on to jack stands (don’t ever work on or get under a car supported by only a jack!!). Since you will be taking off the wheels, if you happen to have 4 jack stands, use this time to rotate your tires if you need to….
STEP 2
Place the catch pan under the brake assembly to collect the brake cleaner as it drips down. Spray the calipers liberally and use the wire brush to remove any caked on or hard to remove brake dust, oil, dirt, etc. Most brake cleaners are fast drying, so continue spray/brush them clean until they look fairly clean. While the caliper is drying, you can begin the next step.
STEP 3
Use the newspapers to mask off any areas that you do not want to be painted…the wheel wells, brake hose(s), rotor backing plate…in my case, I did not mask off the rotor because I was going to change it out anyhow, so you may want to. If a little paint gets onto the face of the rotor, it’s not a big deal because it will come right off in normal driving BUT…DO NOT get any paint into the front rotors’ vents as this may lead to decreased cooling/heat dissipation capabilities of the rotor assembly.
Also remember to mask off the bleed nipple so that no paint can get in and possibly clog it up.
STEP 4
After everything is prepped, and the brake cleaner is completely 100% dry, you can now start painting. The trick is to do several thin coats as opposed to 1 or 2 thick coats. The reason for the thinner coats is to significantly reduce the required drying time, and prevent running/dipping. I ended up doing 5 coats with 15-30 minutes between each coat. How many you do is completely up to you. Also, spraying on a clear coat is also an option that I have heard looks very nice.
Here’s the finished product
Here’s the FINSHED-finished product:
BEFORE
AFTER
Remember you can do any color you'd like and this is a VERY easy DIY that you can definitley do on your own on a Saturday morning (assuming you have two funtioning wrists ). ENJOY!!
Old 04-09-2012, 08:28 PM   #2
Qs91Coupe
Qs91Coupe's Avatar
Real Name: "Q"
Qs91Coupe is on a distinguished road
Glad I found this one again. Great DIY!!
"Out with the old and in with the new." 3.5 hybrid 5MT LS
Check out my 4 sale thread:Click here!!
Qs91Coupe is offline   Reply With Quote
Old 04-10-2012, 07:07 AM   #3
White Rider 92
White Rider 92's Avatar
White Rider 92 is on a distinguished road
its a cool DIY but if you removing the rotor anyways why just not remove the caliper? Atleast you can hang it with a hanger so you wont unplug it. It came out nice though
White Rider 92 is offline   Reply With Quote
Old 04-10-2012, 08:09 AM   #4
Qs91Coupe
Qs91Coupe's Avatar
Real Name: "Q"
I was thinking the same thing. I'm going to keep my rotors so going to remove the caliper and wrap everything in newspaper and spray spray spray.
Old 04-10-2012, 02:29 PM   #5
I should point out that when this DIY was made back in 2004 or 05, I was recovering from a broken wrist. So I only had full use of one hand. My wrist that had been broken couldn't even support the weight of the caliper without being in excruciating pain
My uncle actually had to come over and help me with lifting stuff for the job lol.
Old 04-10-2012, 02:34 PM   #6
Qs91Coupe
Qs91Coupe's Avatar
Real Name: "Q"
That's dedication to the forum.
Old 04-10-2012, 02:52 PM   #7
few things real quick, if u don't wanna get paint all over the rotor, i just cover the rotor area with either a rag or news paper but a rag works really well, that's how i do mine, just cover everything but the caliper and bracket with the rag (old tshirt) and paint, very quick and simple process. end result...
Old 04-10-2012, 05:30 PM   #8
LowPSI
LowPSI's Avatar
Real Name: John
Hopefully soon, I'll be DIYing my calipers. Great DIY.
PS, I bought the (white) ACURA lettering for the calipers on eBay - $6 for a set
I am here: http://tapatalk.com/map.php?tgmbio
Old 04-10-2012, 06:16 PM   #9
BEFORE
AFTER
I love the way the "before" pic has rusty old rotors and the "after" pic has the shiny drilled and slotted rotors. Reminds me of those wrinkle cream or
hair replacement ads.
Old 04-11-2012, 08:11 AM   #10
Krizno
Small fry
Real Name: Matt
Krizno is on a distinguished road
Looks like the box of rotors I have in my bedroom lol
"My Legend comes stock with like 18 bitches!"
Krizno is offline   Reply With Quote
