Old 06-03-2009, 05:31 PM   #1
Default Fan Control Unit Repair
Originally Posted by Jay P
Hi all, thought I’d add a post for those who are suffering with whacky radiator fan & A/C behavior.
Here’s the symptoms I had:
A/C clutch would engage at every start (A/C switch in the off position ! ) for ~ 5 to 10 minutes.
If it was hot and the car restarted after an hour or less, the A/C would not work, no clutch engagement.
The car came to me with a worn out A/C condenser fan.
The rad fans would run at high speed at every start for a few minutes. At times the fans would turn on and off and vary their speed.
So A/C on cool mornings, and no A/C on hot afternoons getting into a parked car… grrrr
The cure, you guessed it, resolder some of the joints on the fan controller board.
I had eyeballed the board previously and it seemed ok, during inspection #2 I got out the magnifier and found about 10 bad solder joints. What I saw were circular cracks in the solder joints on the back of the board. The solder joints are about 1/16” in diameter, the cracks ran around the wire of the attached component and formed circles about 1/3 of the diameter of the solder joint. This left the wire attached to a little cone of solder that had separated form the main part of each affected joint. Presumably these cracks were caused by thermal cycling, perhaps the amount of solder applied was inadequate. In any event I resoldered using a small soldering iron (not a soldering gun) and some fine electronic solder. It seems to work just fine now.
Cheers, Jay
Originally Posted by kitchwatembo View Post
well if anyone else needed to know what the RFC looked like i got some pics
also i have a picture of the contacts, and i needed to know, which of the contacts must be re soldered? is it just all of them or only a certain few?
thanks for any help
Old 01-27-2010, 10:51 AM   #2
mrpuffin708
mrpuffin708 is on a distinguished road
can anybody tell me or show me where the fan controller board is on a 90 sedan. my fans are not working all of a sudden and the motors are good... i just cant figure out where the problem is. any help would be greatly apprecitated.
thanks
btw. i love this forum. i havent had my legend too long and this forum has become my best friend.
mrpuffin708 is offline   Reply With Quote
Old 01-27-2010, 11:38 PM   #3
mrpuffin708
thank you for fixing the pics. can you tell me where the controller is located?
Old 01-28-2010, 12:51 AM   #4
telafonic
telafonic's Avatar
telafonic will become famous soon enough
It's a pain to get to. It's up inside the driver's side dash. You have to lay upside-down and look up to see it.
Remember we have an online manual. Here is a pic.
Yours might not have a penny on it though.
telafonic is offline   Reply With Quote
Old 01-30-2010, 01:06 PM   #5
mrpuffin708
can anyone show me where the ecu is in a sedan. its not under the passenger carpet... i have no idea
Old 01-30-2010, 01:59 PM   #6
The ECU for the Sedan is under the passenger seat.
Old 01-30-2010, 02:10 PM   #7
Wayne-A-Ferd
The Slow Cruiser
Wayne-A-Ferd's Avatar
Real Name: Wayne
thanks bro
