Old 02-15-2011, 08:08 AM   #1
willis95gs
willis95gs is on a distinguished road
Default worn door hinges
My drivers side front door has a slight sag to it...it sticks when u try to open it... it appears the top hinges is the culprint. Acura wants 85 per hinge. Has anyone else had these problem... it makes sense being the car is 16 years old and that's the most commonly used door. Should i replace both hinges.. its driving me nuts. I don't see any rebuild kits out there for the bushings and haven't found much on it from searching... i know there has to be others with this problem.
willis95gs is offline   Reply With Quote
Old 02-15-2011, 09:31 AM   #2
Reboticon
Lord Of The Clunker
Reboticon's Avatar
Its probably not the hinge, tho its possible. Its usually the little middle piece that breaks around the metal.. I forget what it is called.
Old 02-15-2011, 09:45 AM   #3
cakes
The Dream
cakes's Avatar
The pin is what goes bad. I think they're interchangeable between all the doors so if there's a JY near you, you could take the hinges off one of the back doors, pop the pin out and put in your front door.
http://www-personal.umich.edu/~wksebati/Untitled_HDR2.jpg
Guy on Camry Forum:
[The Legend] stops like a fat kid for twinkie... Hondas have REAL brakes, not like Toyota, who can't make proper brakes and a good turning radius if their lives depended on it
WTB: G1 LS Sedan Fuel Sending Unit, Heater, & Tan Drivers side knee panel- PM me
Old 02-15-2011, 10:46 AM   #4
willis95gs
Exclamation
Ill have to look into the pins......yeah that black thing in the middle that slides in and out is what keeps the door from slamming shut on you. That's bad to..lol I've had my door swing shut on my shin quite a few times. I think i need to replace all it. Doesn't help that these cars have some heavy ass doors...but than again its a luxury car and that weight is what gives it that solid feel
Old 09-04-2011, 05:45 PM   #5
J.Kurl
ANTI CORPORATE
J.Kurl's Avatar
J.Kurl is on a distinguished road
Tclyde and I have a small wager on my grinding hinge noise. I say its the hinge, he says its a bad door detent rod? Id like to know more..
J.Kurl is offline   Reply With Quote
Old 09-04-2011, 07:38 PM   #6
I just changed my detent rod, it causes the door to pop when opening/closing and it won't stay open.
That part has nothing to do with sagging.
Use Caution with Worn Stock Shocks!! TSB OneBadKA9RL 1st Gen. RL General Discussion 5 05-29-2015 06:26 PM
how do you grease the door hinges? Wayne-A-Ferd 2nd Gen. Legend General Discussion 14 02-22-2011 04:34 PM
FS: Type II badge, Chrome 5-sp shift knob, coupe door handles and door seals. +++ alittlethin OEM Parts 5 06-19-2010 04:51 PM
FS: Type F worn drivers seat with motors Jonslegend OEM Parts 2 08-12-2009 12:18 AM
