Old 12-30-2009, 01:36 AM   #1
kitchwatembo
shot caller
kitchwatembo's Avatar
Default Blower fan only works on max
I get no fan unless it clicks into the max position. It's really annoying because I have to have the loudest setting if I want any fan.
I have an L model so its manual control.
Has anyone had similar problems or knows the fix?
thanks
My 87 Legend L Sedan
-jason
Old 12-30-2009, 07:34 AM   #2
NuclearSymphony
130R
NuclearSymphony's Avatar
Real Name: Erik
NuclearSymphony will become famous soon enough
Any chance it's the switch? Or, possibly the connection behind the switch.
NuclearSymphony is offline   Reply With Quote
Old 12-30-2009, 07:39 AM   #3
Also make sure the blower fan is cleaned out.
Old 12-30-2009, 08:02 AM   #4
kcf
kcf's Avatar
kcf is on a distinguished road
Not sure about a G1, but I had the exact same thing happen on my G2 Coupe. I had to replace the blower resistor (mine was expensive) over $100. I should have gone to the junk yard
Got Boost?
kcf is offline   Reply With Quote
Old 12-30-2009, 08:22 AM   #5
Beat me to it...can't remember ever seeing this on a G1, but my sister's G2 had this problem and replacing that unit was a super easy fix...$7 at the junkyard too
Old 12-30-2009, 11:15 AM   #6
^ +1 ...worn out limiter (resistor) switch will most likely be the culprit; as previously stated!
Old 12-30-2009, 01:16 PM   #7
kitchwatembo
shot caller
i saw that fix in the g2 section, but where is the resistor in a g1? i couldn't find it at acuraoemparts.
it might be the switch but i dont know how to test it, the tests in the FSM seem to only cover the buttons for fresh/rec and vent/hi-lo/etc.
once again thanks for all the quick replies
-jason
Old 12-30-2009, 01:42 PM   #8
awelliott
Senior Junior Member
Real Name: Tony
awelliott will become famous soon enough
I believe the resistor in the G1 is part of the function control panel. There are also a couple of relays for the blower - I think they're located down by the blower motor itself. I believe the relays are the same, but one controls high speed. However, it looks like if one of those were the culprit, then you'd have no blower at all. In any event, they're easy enough to test if you have the FSM.
awelliott is offline   Reply With Quote
Old 12-30-2009, 04:04 PM   #9
kitchwatembo
shot caller
separate but related, does anyone know what this switch does? its on the bottom of the ac/heater controls
-jason
Old 12-31-2009, 12:03 AM   #10
kitchwatembo
shot caller
blower motor relay's are both good, turns out it was the power transistor. for anyone in the same boat as me here is the transistor, most of what you can see is the heatsink. its located right next to the blower motor behind the glove box.
that cant be right haha
tags: power transistor, blower motor relay, relay
blower, blower switch, fan, fan switch, max air only
radiator fan/condensor fan/horn relays RobRiguez OEM Parts 5 09-02-2009 05:50 PM
Just wow real life mad max GreekPower The Water Cooler 14 08-20-2009 12:48 AM
How The Differential Works Acura Brother The Water Cooler 8 08-10-2009 11:30 PM
what u guys think bout my custom air max 95? BklynSoulja The Water Cooler 13 07-20-2009 10:08 PM
xpressive's ride ('94 KA8 in the works) xpressive Second Gen Legend Gallery -- 1991 - 1995 14 06-09-2009 10:54 AM
