Old 03-03-2014, 09:37 PM   #1
007Legend
S.L.A.B.
007Legend's Avatar
007Legend is on a distinguished road
Exclamation Brake pedal goes to floor after 3 master cylinder replacements
My mechanic and I have been dealing with an issue with my brakes on my 91 Sedan. The brake pedals go directly to the floor. No mushiness, no slow fall to the floor, just straight to the floor. Making the car unsafe to drive at all.
He says there are no leaks, he bled the brakes 3 times and has replaced the master cylinder 3 times as well. Is there anything else to check for besides the MC and air in the lines?
Someone at the shop also asked if we thought it was the ABS Module, but I did not know how to diagnose issues with the ABS and I figured the ABS light would be on or flashing, which it is not.
007Legend is offline   Reply With Quote
Old 03-03-2014, 09:55 PM   #2
ari_one
MeltingInTheSun
ari_one's Avatar
Did your mechanic bench bleed the master before installing? You should also check all the lines going into and out of the ABS to make sure you don't have a leak there. I'm assuming your mechanic already checked the brake booster too?
Old 03-03-2014, 10:00 PM   #3
007Legend
S.L.A.B.
007Legend's Avatar
No he hasn't, but what are the symptoms of a brake booster failure? He thinks it is the ABS system under the hood that needs replacing.
Old 03-03-2014, 11:52 PM   #4
Guario
Guario is on a distinguished road
In such case you would have some back flow from the MC reservoir to the ABS reservoir, or a brake fluid leak under the ABS assembly area. The ABS assembly serves as partitioning valve for our cars. Try bleeding the ABS unit, there is a DIY from other Acura model that works well for Legends, and without the special tool. Else, a failed caliper or broken brake line.
Guario is offline   Reply With Quote
Old 03-04-2014, 01:16 AM   #5
A failed brake booster will cause the pedal to hard. The brake system is loosing pressure somewhere so there is definitely a leak in the system. You don't have to loose a lot of fluid for the system to loose pressure either. Next time try having someone pump the pedal while you inspect the system.
Old 03-04-2014, 04:44 AM   #6
Make sure you are bench bleeding the master cylinder and bleeding the brakes in the correct order. Are you 100% positive there isnt a leak in one of the hard lines or rubber lines, possibly even a cracked caliper where the piston seal is leaking or something of that sort?
Btw the correct procedure is LR/RF/RR/LF
Old 03-04-2014, 12:37 PM   #7
Andyrst
Refinement Engineer
Real Name: 1993 Acura Legend Coupe LS
Andyrst is on a distinguished road
Send a message via AIM to Andyrst Send a message via Yahoo to Andyrst
your fluid is possibly going into the booster, it is only when the booster completely fails that the pedal goes HARD...from the booster it is being sucked into the manifold [via the vacuum line] and you are expelling it out your exhaust....pull the vacuum line from your booster and chk for residue.....I just went through this with my daughters GS
Andyrst is offline   Reply With Quote
Old 03-04-2014, 02:15 PM   #8
Very important that the bleeding be done in the correct sequence as well!
Old 03-05-2014, 05:46 PM   #9
Beyond~Measure
OOOOoooowwwwWWWW
Beyond~Measure's Avatar
Beyond~Measure is on a distinguished road
Get a new mechanic.... I once had a "Acura/Honda" Mechanic tell me he couldn't figure out why my legend's fans were working erratically after having my car for 3 days.... Smfh...
91LS 2002-11 R.I.P. (Enter 92L5Speed 2013-)
Beyond~Measure is offline   Reply With Quote
1991, abs, brakes, master cylinder, sedan
Brake problem, pedal slowly to floor, 89 L ABS cassidy 1st Gen. Legend General Discussion 7 10-28-2015 05:05 PM
Brake pedal play and front clicking sound after Master Cylinder Replacement cakes 1st Gen. Legend General Discussion 15 05-31-2013 10:30 AM
Brake Master Cylinder 91RosewoodBrown OEM Parts 4 09-30-2010 04:47 PM
FS: Brake Master Cylinder alittlethin OEM Parts 3 11-02-2009 04:55 PM
