Old 10-28-2019, 12:50 AM   #11
4HondaOwner
Premium Gas Only
4HondaOwner's Avatar
Real Name: Kevin A
When I owned my sedan, I once had a situation long before my BHG that scared the crap out of me. The gauge spiked up near the top, and was stuck there. A quick trip to my then mechanic and he quickly solved the problem. On top of the area over by the thermostat there is a little piece called the breathing water bolt. (19616-PC1-000) It has something to do with the thermostat and also the temperature gauge. It has some internal wax membrane that makes it work correctly. He had one laying around, it was put in and my problem was solved. Since then I've pulled several from junkyard cars...
6-1-2020 * 94 LS Coupe 6 Speed 335,041 miles * May 2020 miles driven = 96
Old 10-28-2019, 01:55 PM   #12
IamPlan_B
are you referring to the temp gauge sending switch? I have replaced it and the single wire that it connects to. I even replaced the temp gauge in the dash as well.
Old 10-28-2019, 03:29 PM   #13
4HondaOwner
Premium Gas Only
Real Name: Kevin A
Yes, that's the part.
Old 10-31-2019, 12:28 PM   #14
IamPlan_B
could be, not sure. I did replace with a new one from auto zone. it doesn't feel like she's overheating , although the needle says it is.
Old 11-05-2019, 08:14 AM   #15
tstint16
tstint16's Avatar
tstint16 is on a distinguished road
When you add coolant with the Lisle funnel do you also crack open the bleeder bolt once you see coolant coming out close it back?
tstint16 is offline   Reply With Quote
Old 11-07-2019, 09:45 AM   #16
srqlegend
The part number is: Bolt, Breathing Water - Acura (19516-PC1-000)
Originally Posted by 4HondaOwner View Post
When I owned my sedan, I once had a ... On top of the area over by the thermostat there is a little piece called the breathing water bolt. (19616-PC1-000) It has something to do with the thermostat and also the temperature gauge. It has some internal wax membrane that makes it work correctly. He had one laying around, it was put in and my problem was solved. Since then I've pulled several from junkyard cars...
FS: ACURA LEGEND BLOWER MOTOR SPEED TRANSISTOR RESISTOR HEAT 077800-0172 jose3030 OEM Parts 1 02-27-2016 12:35 PM
93 legend L radio issues lcole 2nd Gen. Legend General Discussion 12 01-29-2014 10:32 AM
Lack of heat issue on 3.5 Legend Sedan metpage 2nd Gen. Legend General Discussion 3 01-11-2011 07:46 AM
1988 Legend L AC issues wesmagyar 1st Gen. Legend General Discussion 7 09-12-2010 10:24 PM
heat heat an heat issue help 90ls 1st Gen. Legend General Discussion 24 01-28-2010 07:22 AM
