Old 11-13-2010, 10:57 AM   #11
nightstalker
nightstalker's Avatar
Real Name: Omar
nightstalker is on a distinguished road
Actually I did test the trans it shifted good. Only problem was how to mount the neutral switch. I can't remember if iI had a cel though. I found a trans on Ebay for 300 so I got that instead. Why are you asking? you can try it.
nightstalker is offline   Reply With Quote
Old 11-13-2010, 11:36 AM   #12
im thinkin about picking up an RL that has a bad tranny...the legend has a better tranny so i figured id see if it could be modded to work. worse comes to worse i could always just get an RL tranny for 150 bucks at my local yard
Old 11-13-2010, 11:57 AM   #13
nightstalker
Real Name: Omar
Yeah you can make it work.... You just have to make a custom bracket and or lengthen the shifter rod. I would just get the rl trans and save you the work.
Old 08-16-2011, 05:09 PM   #14
Legendfansinceday1
Legendfansinceday1 is on a distinguished road
I wanna try to do a manual swap from a G2 legend 5 speed is it possible
Legendfansinceday1 is offline   Reply With Quote
Old 08-18-2011, 04:21 AM   #15
Your going to have some working fitting the clutch and fab'ing a clutch system
since the RL isn't designed to take one.
Although you could possibly adapt a GS 6MT one to fit with some custom work.
I don't know how far the ECU would make a fuse if the AT computer isn't doing anything.
Matt should know that.
What does a Legend motor+ auto tranny weigh? LegendLand 2nd Gen. Legend General Discussion 10 07-01-2010 04:32 PM
tranny Qs CRiSS 2nd Gen. Legend General Discussion 4 06-06-2010 06:53 PM
used tranny (""\(0,o)/"") OEM Parts 5 03-26-2010 05:18 PM
Tranny DIY lookin for a good one pls.... First G2 tranny mochudley 2nd Gen. Legend General Discussion 1 02-16-2010 08:31 AM
Used Tranny vs Rebuilt Tranny spcgloc 2nd Gen. Legend General Discussion 14 09-26-2009 03:47 AM
