Old 11-12-2010, 06:40 PM   #1
Default Legend tranny in an RL?
Is this possible? Has it been discussed in length? I couldnt find any threads specific to what im looking for so any guidance would be greatly appreciated. Thanks
Old 11-12-2010, 07:08 PM   #2
T-Clyde
Canter-Buried Alive
T-Clyde's Avatar
Real Name: Tommy
You talkin about doing a manual conversion? Or just putting a legend auto trans in the rl?
OEM Parts for Sale
Maintenance > Modification
Old 11-12-2010, 07:20 PM   #3
just putting a legend auto trans in an rl. im figuring if the 3.5 can be swapped in a G2 then maybe the tranny of a G2 could swap in an RL...?
Old 11-12-2010, 07:28 PM   #4
T-Clyde
Canter-Buried Alive
T-Clyde's Avatar
Real Name: Tommy
In theory it seems like it would work, sr5matt needs to get in here.
I could blindly theorize all day about tcu's and whatnot. But it would be futile as I would be smoking my 2nd blunt in a row, and blunt or not, I have no idea what I'm talking about.
OEM Parts for Sale
Old 11-12-2010, 08:21 PM   #5
nightstalker
nightstalker's Avatar
Real Name: Omar
nightstalker is on a distinguished road
No It won't work because of the neutral switch unless you make a custom bracket.
nightstalker is offline   Reply With Quote
Old 11-12-2010, 09:50 PM   #6
I'm pretty sure it has something to do with RL's having OBDII's
Old 11-13-2010, 12:25 AM   #7
onthe3rdday
onthe3rdday's Avatar
onthe3rdday is on a distinguished road
obd and transmissions are mutually exclusive. He needs to worry about mounting/ TCU and sensors. Sorry Mondi, no effin clue!
onthe3rdday is offline   Reply With Quote
Old 11-13-2010, 10:28 AM   #8
im pretty sure a mount could be made, no?
nothin wrong with speculation...thanks for the input so far guys. i could call matt but then it really wouldnt benefit the rest of the forum...im sure he will pop in here at some point
Old 11-13-2010, 10:50 AM   #9
nightstalker
Real Name: Omar
The difference is in the trans housing itself it changes where the shifter goes. When the trans on my Rl i tried putting the legend trans. Everything its the same, same plugs, mount. and I don't think tcs is a problem. only problem i see its how the ecu makes the shifts. I did not ran the car that much because of the neutral switch problem.
Old 11-13-2010, 10:53 AM   #10
so the OBDII ecu probably wont work with the legends OBDI tranny.
What does a Legend motor+ auto tranny weigh? LegendLand 2nd Gen. Legend General Discussion 10 07-01-2010 04:32 PM
tranny Qs CRiSS 2nd Gen. Legend General Discussion 4 06-06-2010 06:53 PM
used tranny (""\(0,o)/"") OEM Parts 5 03-26-2010 05:18 PM
Tranny DIY lookin for a good one pls.... First G2 tranny mochudley 2nd Gen. Legend General Discussion 1 02-16-2010 08:31 AM
Used Tranny vs Rebuilt Tranny spcgloc 2nd Gen. Legend General Discussion 14 09-26-2009 03:47 AM
