Old 06-18-2009, 07:40 PM   #1
Biggg72
The Big Bald 1
Biggg72's Avatar
Biggg72 is on a distinguished road
Send a message via MSN to Biggg72 Send a message via Yahoo to Biggg72
Default opinion survey: kinetic vs optima
i am looking for opinions from anyone who has used a kinetic battery and a yellow top battery. if you havent had both i dont want to know about your opinion of one.
for those that have had a kinetic battery if you use there system to see which battery you need ad you put one in that is 2 steps above, what is the positive and negative of this? it was said i needed the 1400, but i was thinking of putting a bigger one in.
Golfer Jerry Pate, an Alabama graduate and the 1976 US Open winner, said it best when he walked out of the Crimson Tide locker room after the game.
That, Pate said, was an ass-kicking.
Biggg72 is offline   Reply With Quote
Old 06-18-2009, 08:42 PM   #2
I've used all including a redtop. what exactly are you using the battery for?
I had the 2000 for my stereo and now its just a 600. I had a regular die hard under the hood and swapped that for a redtop. I had a yellow top and it died 2 years like clock work. red top is going strong
Old 06-18-2009, 08:58 PM   #3
Biggg72
The Big Bald 1
Biggg72's Avatar
come baby boy you know im running my sounds. i ve had interstate.....hated it, had cranking power tho., had a autozone, oreillys, and some other special.....all sucked. ive had 2 yellow tops, the 1st quit in 2 years like yours, and the 2nd is still pushing.
the system im pushing is the biggest to date and the yellow top handles it with a very slight headlight dim at full blast, all the others it was like i had disco lights on the front of my vehicles.
i read an article and the people swore buy kinetic, so i wanted a vs. opinion about the 2 because the price i saw was 3 to 4 bills.
so why did you go from 2000 to 600?
Old 06-18-2009, 09:00 PM   #4
well I have a kinetik for sale...HC 2000
But what I mean by is it running your hole system + car or seperated from the car and running only the system. That makes a diff
Old 06-18-2009, 09:02 PM   #5
Biggg72
The Big Bald 1
Biggg72's Avatar
whole car, thought about the seperate battery but havent been sold on needing that in the car.
Old 06-18-2009, 09:09 PM   #6
I have both optima and kinetik. If your running a large setup you need a seperate battery for your system. I have two kinetik 2400's just for my system.
Old 06-18-2009, 09:14 PM   #7
Biggg72
The Big Bald 1
Biggg72's Avatar
bigboy how many watts are you runnning? out of curiosity how did you run your wires for the extra batteries? got any pics of the battery setup?
another ?, has anyone used a kinetik power supply?
Old 06-18-2009, 09:31 PM   #8
I have 3- Rockford 1000a2's one for each sub.1- Rockford 800a4 for mid bass and a Rockford 200a4 for my highs. I use stinger 0 gauge hpm power wire, and the way i ran my extra batteries is: 0 gauge power from the optima to the kinetik and the same to the ground, you don't want to ground your second/third battery to the frame. I know alot of ppl say use a isolator for the second battery but I had to send one of my kinetik's back because it died and that when they told me not to use a isolator.
Old 06-18-2009, 09:33 PM   #9
hmm I used a isolator on both of my kinetiks, both are fine. I just run a redtop for starting and everything else is running off the 600.
Old 06-18-2009, 09:46 PM   #10
Biggg72
The Big Bald 1
Biggg72's Avatar
ok so maybe the question should be, on a percentage level, how much more efficiently do you think your car runs with the extra batteries? i might dive into this an open up some other doors.
B.B. do you have a pic of your battery setup?
