Go Back   AcuraLegend.Org - The Acura Legend Forum for All Generations of the Honda / Acura Legend; 1986 to Present > First Generation RL (Third Generation Legend) -- 1996 - 2004 > 1st Gen. RL Performance Enhancements
Old 02-14-2015, 05:06 PM   #1
Dplas
Dplas is on a distinguished road
Default 3.5 rl swap with aluminum crank pulley questions
Does anyone else have one? My legend had it when I got it and my roommate says it will mess up my main bearings
Dplas is offline   Reply With Quote
Old 02-14-2015, 09:06 PM   #2
The only thing I'm worried about for the sake of my main bearings is the presence of oil.
If your roomate has some hard proof, and I'm talking on the C32A or C35A engine, then that would be helpful. If our lower end was that fragile then every one of us that put an MT flywheel on a 3.5 would be in big trouble.
I understand the merits of balancing both ends of the crank, but I think Honda made bullet proof mains because not even they balanced everything to perfection. Same two piece C32A pulley was fit to the A/T, Solid and Dual mass flywheels.
I think your 3.5 is fine with a lighter pulley, but if you get uneasy about it there are plenty that would send you a stock pulley for a straight up trade.
Old 02-14-2015, 09:22 PM   #3
LowPSI
LowPSI's Avatar
Real Name: John
LowPSI will become famous soon enough
What he said!
Sent from my iPad using Tapatalk HD
LowPSI is offline   Reply With Quote
Old 02-15-2015, 10:49 AM   #4
Mike Diaz
Super Duper Member
Mike Diaz's Avatar
Mike Diaz will become famous soon enoughMike Diaz will become famous soon enough
tell your roomate he's wrong. Tell him we're dealing with a balanced bottom end that doesn't need external balancing like a small block Chevy engine.
RIP Fut.
3.5 swaps, head gasket replacements, and 5/6 speed swaps done in less than a week. PM for a quote.
Mike Diaz is offline   Reply With Quote
Old 02-15-2015, 12:20 PM   #5
ThirstyTree
ThirstyTree's Avatar
Real Name: Mark
ThirstyTree is on a distinguished road
Is the 3.5 still internally balanced? I know the 3.2 is...... Either way 3.5 is smoother and has balance shaft
Sent from my iPhone using Tapatalk
while pooping
ThirstyTree is offline   Reply With Quote
FS: 3.5 Aluminum Crank Pulley 94LegendaryAcuraGS Non-OEM Parts 35 05-24-2013 01:44 PM
FS: 3.5 Aluminum Crank Pulley Ablest31 Non-OEM Parts 11 03-26-2013 08:57 PM
FS: C27 Aluminum Crank Pulley "Chopped" Non-OEM Parts 6 03-15-2013 02:02 PM
aluminum crank pulley 95pearlwhiteGS OEM Parts 3 11-27-2012 06:31 AM
91-92 Crank Pulley- will take aluminum too. holyabish1 OEM Parts 1 12-18-2010 06:53 PM
