Old 12-05-2018, 08:04 AM   #1
Markpti
Markpti is on a distinguished road
Default Introducing myself
Hello. I'm Markpti I appreciate any advice members may offer regarding my 1992 Legend Sedan. It has 104,000 miles. Purchased from florida 3 years ago. I live in the Rochester, NY area. I keep the Legend off road in the winter to avoid the salt damage.
I've need to replace the R&P Bellows and am having the Acura Dealer machine flush the automatic transmission in hope to improve some shifting movement as I decelerate in D4. No movement when I decelerate in D3.
On the R&P Bellows issue, I'm planning to order from RockAuto, new unvented Bellows. Should I be considering any other R&P parts replacements since I'm going through that effort?
Any thoughts or advice is appreciated.
Markpti is offline   Reply With Quote
Old 12-05-2018, 10:26 AM   #2
Captain Slow
Ken
Captain Slow's Avatar
Captain Slow has a spectacular aura aboutCaptain Slow has a spectacular aura aboutCaptain Slow has a spectacular aura about
A transmission fluid drain and fill is probably all you need, but this 4x tranny flush has been popular since the beginning of time if you want to do everything you can:
http://forums.acuralegend.org/4x-tra...ion+drain+fill
https://www.acura-legend.com/vbullet...lush-gil-4818/
Old 12-08-2018, 06:34 PM   #3
JMan
JMan's Avatar
Real Name: J
JMan is on a distinguished road
Welcome!
I too would say you should probably just drain and fill.... Alot of transmission "Flushes" include cleaners and chemicals that aren't necessarily good for the transmission. Honda themselves do not recommend the use of any chemicals in any of their fluid systems and the recommended ATF service for hondas is just a drain and fill.
JMan is offline   Reply With Quote
[IMG] code is Off
introducing myself darkrr New Member Introductions 2 03-02-2014 08:18 PM
Introducing My '94 LS 6MT Project, Nearly Done Hockeyman Legend Builds 57 06-02-2013 06:44 PM
Introducing Legend Search! vinh291 The Water Cooler 25 02-20-2013 07:15 PM
Introducing joesgotsol 95 Legend joesgotsol New Member Introductions 21 03-23-2012 01:51 PM
Finally introducing my self!! T.O New Member Introductions 11 04-21-2011 01:50 PM
