Old 06-11-2018, 03:25 PM   #1
Jmshadows
Real Name: Jose
Jmshadows is on a distinguished road
Default Hello I'm Jose. I'm a diy mechanic could use some tips
I have a 94 Acura legend 6spd, I have my brake light, abs light, and tcs light on. I read on another thread about a check list I got my tail lights on. I haven't thought about checking my brake fluid I might do that in a bit. Is there anything I can do to fix this without taking it to someone more qualified?
Jmshadows is offline   Reply With Quote
Old 06-11-2018, 07:45 PM   #2
Welcome to the forum, Jose.
You'll have difficulty finding anyone more qualified than the folks on this forum.
With the help of this forum you can easily figure out the problem yourself. The key is to proceed in logical steps.
Checking the fluid level in both your Brake Master Cylinder reservoir and ALB reservoir is the first step. Top them off and report back.
Old 06-18-2018, 09:32 AM   #3
radieon
What the Diff
radieon's Avatar
I agree. The brake light on the dashboard in Hondas/Acuras will stay red even after releasing the hand brake to indicate that brake fluid level is low. If you move the car while the brake light is on, you'll trip the ABS light as well since the ABS system depends on enough brake fluid to function.
Let us know if that worked for you.
radieon is offline   Reply With Quote
Old 06-30-2018, 02:28 AM   #4
srqlegend
Welcome jose!
Checkout the DIY section in the forums.
Also download the Factory Service Manuals:
http://forums.acuralegend.org/all-he...ls-t20449.html
http://www.acuralegendwiki.org
also has some good information.
Old 09-18-2018, 10:03 AM   #5
JJtheRippah
KA7 Noob
Real Name: Jayy B.
JJtheRippah is on a distinguished road
Any luck? Reservoir low? Had the same issue when I first bought mine, topped off brake fluid and reset light (disconnected battery). Good to go!
JJtheRippah is offline   Reply With Quote
[IMG] code is Off
Took my car to a mechanic. Need help! dominicjansson 2nd Gen. Legend General Discussion 10 03-12-2013 06:26 AM
94 GS 6-speed San Jose chingatorz "Not Mine" 6 03-03-2013 12:33 AM
Pitcher Jose Lima Dead at 37 byalegend The Water Cooler 2 05-23-2010 06:38 PM
Looking for a mechanic in Queens legenditalia Northeast US Region 8 04-23-2010 10:19 AM
1995 Acura Legend LS Coupe Desert Mist 6-Speed San Jose, CA Lsportline43 "Not Mine" 19 10-11-2009 12:46 PM
