Old 07-01-2019, 05:39 PM   #1
Smootman
Smootman is on a distinguished road
Default Valve Cover Gasket Circular Plug
I'm replacing my valve cover gasket, again. Some gasket kits have a circular plug and some do not. What is the circular plug used for and has anyone installed them?
Smootman is offline   Reply With Quote
Old 07-01-2019, 06:13 PM   #2
stephen
The plug goes at the back of the camshaft for the back cylinder head. It might be possible to reuse the old one but it would be good to replace it.
I've installed the valve cover gaskets several times. Just remove the valve cover and swap the new one in. There are a few places to apply RTV and a few other parts may need to come out. There are also spark plug seals in the kit as I recall.
Old 07-01-2019, 06:19 PM   #3
stephen
Delete the comment about spark plug seals. I was thinking of second generation.
Old 07-02-2019, 09:19 AM   #4
stephen
The circular plug is also available separately from various parts sites such as rock auto and parts geek.
Old 07-10-2019, 06:42 PM   #5
paulo57509
paulo57509's Avatar
I did the circular plug the last time I replaced the VC gaskets (~3 years ago). I'd recommend leaving it alone unless it's leaking. It's a PITA R&R-ing this thing with the engine in the chassis.
I had to remove the torque strut and angle a drill bit through a hole the mount to drill a hole in the plug in order to pry it out.
It's also a PITA getting the new one in the head - there's no room to tap it in with driver and hammer. In order to get it started into the hole, you need to get the plug past the molded "lip" on the end of the plug.
I ended up trimming off half the lip from the circumference of the plug and using black silicone to ensure it stayed put and sealed. Getting it into the bore required prying against the torque strut mount in order to press it into place.
Kind of explains why the plug that I removed didn't have a lip and was siliconed in place.
FWIW, I plug I used was Fel-Pro P/N CP75015
'87 L-Coupe 5-Speed
Stock; Few Mods
444K Miles - original engine and drivetrain.
Old 07-12-2019, 07:07 AM   #6
stephen
The part in question is part 7 in the following
https://estore.honda.com/acura/parts...&b=E++1001&dl=
I recall now that this part goes in before the cam bearing cap assembly. To install it on an assembled engine I believe it would be possible to loosen the cam bearing bolts and slip it in place though there should be RTV at the parting line between the caps and head at each end. One caution is that the cam cap bolts can get stuck and break while removing them. If it's not leaking there I would leave it alone.
Old 07-12-2019, 06:41 PM   #7
Technically you should loosen the rockers which allows you to tilt the backside up and remove the old/insert the new fairly easily. You should remember to clean the mating surface of the rocker holder and apply a film of HondaBond to keep from seeping.
Old 08-14-2019, 12:43 AM   #8
tiffanyneal
tiffanyneal is on a distinguished road
In any case thank you for helping me.
tiffanyneal is offline   Reply With Quote
Spark plug tube seals and valve cover grommets Cryser 1st Gen. Legend General Discussion 3 01-17-2013 10:15 AM
Valve Cover Gasket Maximus 2nd Gen. Legend General Discussion 8 07-28-2011 02:07 PM
How long should a valve cover gasket job take? KJLegend 2nd Gen. Legend General Discussion 10 04-19-2010 11:41 AM
ebay valve cover gasket kit hotstartup 2nd Gen. Legend General Discussion 3 09-10-2009 08:07 PM
Valve cover gasket set? Which ones? 91RosewoodBrown 2nd Gen. Legend General Discussion 9 07-08-2009 12:20 AM
