Old 02-09-2011, 04:26 PM   #1
Ken
ridin' high
Ken's Avatar
Send a message via AIM to Ken
Default idle problem any ideas!?!?!
hey guys, hows it going. its been a while since I've had a g2, but I've been working on a 91 LS sedan for a friend that has this weird idle problem. When the car is at operating temp, and you rev it or put it into drive, then back into nuetral or park, the idle starts going erratic reving up and down. I've bled the cooling system, and have replaced all of the udle valves, throttle body, etc. any ideas? any help would be greatly appreciated. thanks!
. k e n
Old 02-09-2011, 04:59 PM   #2
Will it happen every time that you rev it and then put it in park? Or just from time to time? How long will it rev up and down for? While it's in park or neutral and being erratic, try revving it to like 1500 yourself and let it come back down and see what happens.
My situation was similar. It would idle erratic only when warm and after being put from drive into park. I once watched it idle funny for 3 or 4 minutes. I didn't have the patience to watch it any longer than that. If I would give it gas up to like 1500 and let it come down in park it would usually cooperate. I got rid of the issue when I fixed a rear water outlet leak and replaced my slightly leaking radiator. I had a known coolant leak that I topped off but I believe the erratic idling was one effect from the leak I had.
Old 02-09-2011, 09:24 PM   #3
Ken
ridin' high
Ken's Avatar
turns out it was a pinched vacuum line.... stupid me. I guess my eyes weren't sharp enough.
. k e n
Old 02-09-2011, 09:54 PM   #4
^Try opening them every once in a while. LOL j/k
Need some help or ideas! Lid`en The Water Cooler 5 05-27-2010 09:04 AM
Idle problem, almost stalls it's self... LegendaryAffinity 1st Gen. Legend General Discussion 50 02-14-2010 09:26 PM
I'm out of ideas Acidic 1st Gen. Legend General Discussion 14 11-12-2009 07:29 PM
Steve's Idle Adjust Screw Problem DallasLedge89 1st Gen. Legend General Discussion 2 09-17-2009 11:51 AM
When it happens (pm ideas) GreekPower The Water Cooler 12 06-21-2009 02:02 AM
