Old 12-06-2011, 04:32 AM   #1
KillSAM6
Old Guy
Real Name: Jay
KillSAM6 is on a distinguished road
Default 5-Speed Problem--Recommendations?
Have a 91' LS Coupe with 161K on it. Have a problem with the 5-spd that started about two weeks ago. It shifts fine, but pops out of 4th gear in cruise (all others are okay). Did some searches on the forum and the Net and followed a recommendation to change the transmission oil to Pennzoil Synchromesh. Improved it for a few days and then back to the same problem.
Anyone got a recommendation for a magic fix or for a good Acura transmission mechanic in the Phoenix area?
KillSAM6 is offline   Reply With Quote
Old 12-06-2011, 04:44 AM   #2
Ouch. That sucks, before condeming it, I would check all the shifter linkages and bushings. Otherwise your gonna have to rebuild or swap in a new trans, which can be cheaper. Sometimes you can find the 5spds for really cheap. Under $200.
Welcome to the forum btw!
Also. I really like the Honda syncromesh fluid but also Gm makes a great fluid, a lot of ppl.have had good luck with.
Old 12-06-2011, 09:26 AM   #3
KillSAM6
Old Guy
Real Name: Jay
Thanks for the recco. Had the car shipped to Phoenix from Northern Virginia recently and they may have banged up the underside. Had a leak from a rubber boot at the back of the transmission that it did not have before shipment. May have bent one of the shift rods as well.
5-spd, 5-speed, manual
HID Bulb Recommendations skylinegtrelite 2nd Gen. Legend General Discussion 14 12-02-2010 08:27 PM
Best HID kits, recommendations? SPARTACUS The Water Cooler 30 10-10-2010 05:18 PM
Need recommendations or help doing 3.5 swap soloist 2nd Gen. Legend General Discussion 9 10-30-2009 03:10 PM
Tire recommendations cakes 1st Gen. Legend General Discussion 17 10-24-2009 11:27 PM
6 speed tranny problem. please help. watch video Romero88 2nd Gen. Legend General Discussion 26 10-03-2009 06:11 PM
