Old 07-16-2009, 10:39 PM   #21
Jonslegend
Ive Got 2nd Gear!!!!
Jonslegend's Avatar
Real Name: Jonathan Roose
Jonslegend will become famous soon enough
i used some window molding sealer crap i havent put them in but did i waste my time and money i wish i would of seen this sooner
It's not Gold, It's Cashmere
Jonslegend is offline   Reply With Quote
Old 07-17-2009, 03:00 AM   #22
Dethred
A-L.com FAIL
Dethred's Avatar
Dethred is on a distinguished road
I did the 3M window weld over July 4th weekend and I noticed a decent difference. I think at least one other mount is bad, so it still jerks on shifts. I know its working some because the car doesn't jerk when putting it into D4 from park or neutral. Previously it would feel like the engine was about to drop out of the car, and sometimes even stall out.
-2013 Porsche 911 C4S - Loaded
-2014 SRT Viper GTS - Loaded with every option.
-2010 Acura TL SH-AWD Tech package (Sold)
-2005 Honda S2000 (15k mi) (Sold, and crashed)
-1992 Acura Legend Sedan (220k+ mile, scraped)
Dethred is offline   Reply With Quote
Old 07-20-2009, 12:35 AM   #23
I wish I could make it red
Old 07-20-2009, 10:21 PM   #24
LegendCanada
Is He Ill?
LegendCanada's Avatar
LegendCanada is on a distinguished road
Should there be any harm in taking off all three trans mounts at one go? I mean would this cause any excess stress on any other components?
I need to do this sooner than later! as the typical story goes my rear trans mount is totally shot and the front two are pretty weak
Truly a legend among Legends RIP
LegendCanada is offline   Reply With Quote
Old 07-20-2009, 10:25 PM   #25
personally, i drove with out a rear mount. your shifting will be very very harsh. also hard accelation will force lots of wear on axles, other mounts and other components.
i wouldn't drive wit out a front mounts. there will be alot of movement of the motor.
Old 07-20-2009, 11:29 PM   #26
You can take all three off at once, it's probably best to keep a jack under both the front of the engine and the transmission. That should also make it easier to re-install after they're filled.
Old 07-20-2009, 11:52 PM   #27
LegendCanada
Is He Ill?
Allright, thanks for the tips! right on i'll have keep this in mind and knock this off asap. So baking the poly filled mounts for 15-20 min after you let them cure for a day should be sufficient for putting them back on?
What's the minimum safe down time before re-install?
Old 07-23-2009, 01:24 PM   #28
Russian
Russian's Avatar
Russian will become famous soon enough
Ordered yesterday, got it today, filling on Saturday.
Russian is offline   Reply With Quote
Old 07-23-2009, 01:33 PM   #29
Chapman89
Former Legend owner
Chapman89's Avatar
Chapman89 is on a distinguished road
I need to do this when I can afford some downtime. How much do the supplies cost?
SOLD!
Chapman89 is offline   Reply With Quote
Old 07-23-2009, 02:05 PM   #30
Originally Posted by Rajca View Post
some duck tape, die grinder and the polly which is about $35 for what alex did, 3mounts, if u want to do all of them id suggest getting 2 gallons.
2 gallons!? You can do all three and have some left over with just one can, which isn't even half a gallon.
auto, fill, manual, mounts, poly
