Old 12-11-2011, 07:24 AM   #1
TopGear1224
TopGear1224 is on a distinguished road
Unhappy What happened and what are my options
So I just got my chipped ecu installed and loving the benefits when 160 miles later.tyranny gone. The d3 or d4 won't move just revs in 2 can feel it trying but still basically just revs when I put in in 2 it sits at 1k rpm. In 1 it almost stalls but moves doesn't feel secure but it does move 3rd is good so is forth. About a week ago I noticed really hard 12 shifts. I but I figured it was my tires like they were jumping or something. I bought ghetto tires. Down shifting gives the same results just revs. Any ways is this fixable and if so how much. This car is at this point my dd. How long can it last like this if I am easy on it. I how hard is a 6mt swap and what all needs to be done my car can only be down a max of 2 days.
TopGear1224 is offline   Reply With Quote
Old 12-11-2011, 07:35 AM   #2
dooley
Virginian
dooley's Avatar
Real Name: Dan
dooley is on a distinguished road
Have you checked your trans fluid level yet? remember car has to be at operating temp. fans must come on twice and car must be running to check fluid level. best to take from park put in reverse then to drive back to reverse and the park before checking . if car has been sitting of course.
dooley is offline   Reply With Quote
Old 12-11-2011, 08:57 AM   #3
ari_one
MeltingInTheSun
ari_one's Avatar
Best to check the manual because I believe it states that car must be turned OFF before checking tranny fluid level (but at operating temp).
Old 12-11-2011, 09:05 AM   #4
Manual states that the car must be at operating temperature and on a level surface. You have up to 1 minute to check the fluid after shutting off the car.
Old 12-11-2011, 02:27 PM   #5
TopGear1224
Default Checked
I checked the trans fluid level about 1 mm above full checked right after i turned off the car after 20 miles. What else could cause this checked connectors at ecu and by the master clyinder both are on tight.
Old 12-11-2011, 02:35 PM   #6
Tippey
Pony
Tippey's Avatar
Real Name: Austin
The manual doesn't say anything about having up to 1 minute after shutting the car off
But yes the car should be off and the fluid should be at operating temperature.
Old 12-11-2011, 02:44 PM   #7
TopGear1224
it was checked it immedatly and about 2 mins later.
Old 12-11-2011, 02:52 PM   #8
[QUOTE=Tippey764;408980]The manual doesn't say anything about having up to 1 minute after shutting the car off
But yes the car should be off and the fluid should be at operating temperature.[/QUOTE
In the legend manual and service manual states that.
Suppose to be 1 minute like I stated before.
Old 12-11-2011, 02:56 PM   #9
TopGear1224
i checked it twice one right away and once 2 mins later
Old 12-11-2011, 03:02 PM   #10
Tippey
Pony
Tippey's Avatar
Real Name: Austin
It doesn't say anything about 1 minute.
slipping auto tranny
What in the world happened?! tw1st The Water Cooler 11 02-26-2010 01:28 PM
what happened to privacy? cakes The Water Cooler 15 02-21-2010 12:31 AM
look what happened to me on 09/09/09 Dracc Southeast US Region 22 10-11-2009 12:00 AM
Well it happened again.... IGotALemon The Water Cooler 15 09-23-2009 04:13 PM
Not sure what happened but I'm here 91LSplendid New Member Introductions 18 06-06-2009 04:15 AM
