Old 02-23-2012, 05:37 AM   #41
clynt101
clynt101's Avatar
Real Name: Clint
clynt101 will become famous soon enough
thanx sir. I saw that, but I heard alex say he likes to use the RL diff??? If its possible I would like to get the info on what needs to be modified.
If the coolant line bungs remain in the casting I could fill these (aluminum weld) or tap and insert a plug.
Is this the only difference??
clynt101 is offline   Reply With Quote
Old 04-04-2012, 11:15 AM   #42
cfrye18
cfrye18 is on a distinguished road
Are the ecu's plug and play from a type 1 to a 3.5rl?
cfrye18 is offline   Reply With Quote
Old 04-04-2012, 12:52 PM   #43
sap
ignore the smoke
sap's Avatar
Send a message via AIM to sap
Depends what you mean by "plug and play", a type I ECU will run a 3.5 swap in a legend, but you can't move an RL ECU to the Legend.
Sig by Cole Austin
RIP Fut RIP l4zy
Old 07-11-2012, 11:37 AM   #44
92legendproject
92legendproject is on a distinguished road
if i do the 3.5 swap and put the type 2 intake and cams can i keep the ecu from the legend or do i have to get the rl ecu?
92legendproject is offline   Reply With Quote
Old 07-11-2012, 11:42 AM   #45
Legend37
Legend37's Avatar
Real Name: Sam
Legend37 is on a distinguished road
You keep the Legend ECU, but you will have to transfer the 3.2 Engine Wire Harness over to the 3.5.
Legend37 is offline   Reply With Quote
Old 07-11-2012, 12:11 PM   #46
clynt101
clynt101's Avatar
Real Name: Clint
and you must get the legend ECU chipped!!! This is if you choose to run the Type II camshafts. There are a few other things that will need to be swapped over from the legend to the RL motor as well.
FYI: Telion and SR5guy can help you with the ECU.
Old 07-11-2012, 11:20 PM   #47
dooley
Virginian
dooley's Avatar
Real Name: Dan
dooley is on a distinguished road
^ incorrect If your car had a type 2 and you put the cams and intake on your 3.5. you should be fine. chipping is not required to do a swap
You need to use the legend injectors. But that all should come off when you pull your type 2 intake off. and put it on your 3.5. You need to pull the passanger valve cover off and swap that out as well. because of the sensor in the back of the valve cover to work with your legend wiring harness. you need to make the oil pressure sensor wire a little longer on the front of the motor and use the rl front harness cover as it has and extention on the bottom for the wire to be protected from the belts.
dooley is offline   Reply With Quote
Old 07-12-2012, 09:56 AM   #48
92legendproject
thanks that helps. (p.s. i have a type1 3.2 so i was gonna buy the type 2 intake and cams do i need to use type2 injectors or will the type1 work just fine?)
Old 07-12-2012, 11:02 AM   #49
Correct, but oh do they run so much better with one!
Old 07-12-2012, 11:29 AM   #50
92legendproject
how would i go about chipping it?
average parts total for 3.5 swap??? pjslegend 2nd Gen. Legend General Discussion 4 02-22-2010 08:45 PM
3.5 swap parts soloist OEM Parts 6 02-13-2010 05:03 PM
WTB: manual swap parts!! MasTeR.LeGenD OEM Parts 12 10-03-2009 08:14 AM
5 speed tranny and swap parts stella OEM Parts 5 08-18-2009 06:37 PM
