Old 06-17-2010, 08:48 PM   #31
^ yea, i'm pretty sure it doesn't fit back, atleast i'm 100% positive both 3.5 swaps i've done it not fitting.
also a RL VSS does infact work.
I also personally like the RL diff more then the legend diff b/c its got better cooling fins since its designed not to be cooled like the legend diff, but probably doesn't make a huge difference.
Old 07-01-2011, 06:04 PM   #32
Is it possible to use the RL TPS portion of the throttle body on a 3.5 hybrid? Using the type 2 intake manifold btw..
If not, what's the difference between the TPS's(?)?
Old 07-10-2011, 02:43 PM   #33
killaswa6
killaswa6 is on a distinguished road
[QUOTE=sr5guy;213706]Identical Parts
A/C Compressor (93-95 Legend only, 91-92 must use Legend or change manifold)
Or change to which manifold if attempting to use the 3.5 AC Compressor
killaswa6 is offline   Reply With Quote
Old 07-10-2011, 03:53 PM   #34
Your question has been answered in your other thread, but since you asked it here as well:
Originally Posted by Quaraxkad View Post
Yes, you can use the RL AC compressor. Since your Legend was initially R12, you will need to swap the AC port manifold from your existing compressor to the RL compressor or your AC hoses will not fit.
Old 07-11-2011, 02:35 PM   #35
Identical Parts
Step 1. Click Search
Step 2. Type in "A/C Compressor Manifold"
Step 3. Find this:
http://i1028.photobucket.com/albums/...oist3/ac11.jpg
Old 12-17-2011, 10:24 PM   #36
gsdreams
Real Name: Larry
gsdreams is on a distinguished road
Anyone want to post up the Tap size for the valve cover if you want to use the RL Valve Cover? Would be a nice addition to this thread and is one hell of a search trying to find the information.
I believe it is a 16x1.5 but I have yet to confirm that.
Originally Posted by Legend37 View Post
All I got to say is, once you drive a Legend, you fall in love forever.
gsdreams is offline   Reply With Quote
Old 12-18-2011, 09:45 AM   #37
That's kind of outside the purpose of the thread. It's something easily measured with a pair of calipers. Also, most people swap over the Legend's valve covers to eliminate this step.
Old 12-18-2011, 09:57 AM   #38
gsdreams
Real Name: Larry
I know most people swap the valve covers, but mine had paint or something on them that was only half destroyed while hot tanking and I have so much on my plate working on engine/differential/transmission/rack and pinion that I would rather just tap a hole and be done with it.
Also, it isn't outside the purpose of this thread. This thread is interchange and parts that can be used. As it says in the first post the RL valve covers can be used, but the hole has to be drilled and tapped.
Knowing what size tap would be part of the parts interchange.
Old 02-22-2012, 07:18 PM   #39
clynt101
clynt101's Avatar
Real Name: Clint
clynt101 will become famous soon enough
I would like to find out what is difference b/t the RL and Legend Diff??? Ive heard that they can interchange but the RL would need some machining??? Is this correct?... Id like to use the RLs since im still driving my 3.2 while building the 3.5. I would also like to add a PG and mount it back on the motor....this way I have least amount of downtime during swaps.
Please lemme kno if anyone has any info.
clynt101 is offline   Reply With Quote
Old 02-22-2012, 11:29 PM   #40
Post #2, 3rd heading down.
average parts total for 3.5 swap??? pjslegend 2nd Gen. Legend General Discussion 4 02-22-2010 08:45 PM
3.5 swap parts soloist OEM Parts 6 02-13-2010 05:03 PM
WTB: manual swap parts!! MasTeR.LeGenD OEM Parts 12 10-03-2009 08:14 AM
5 speed tranny and swap parts stella OEM Parts 5 08-18-2009 06:37 PM
