Old 05-06-2010, 12:17 AM   #21
Main relay for RL same as Legend?
39400-SP0-013 RELAY ASSY., MAIN (RZ-0105) (MITSUBA) 91 - 95 LEGEND
39400-SZ5-A01 RELAY ASSY., MAIN 96 - 04 RL
Old 05-06-2010, 08:19 AM   #22
Dv8
Life Ruiner
Dv8's Avatar
Not sure that helps, they have the same two plugin terminals and curcuitry is identical, so im going to order one and see. I can get it from autozone for 70!
~Dv8
GT-R 3/7/15 9.2 @151MPH | 12/19/13 994whp 895wtq Dynojet 186 1/2 Mile
16 yrs and counting. To many Experts, not enough Results. Where are yours? Retired Legend 616WHP@18PSI 10/11 12.1@124MPH 02/12 N/A 234whp 229lb-ft 13.7@99mph 95 deg. 06/07 Lexus IS-F Nitrous 11.3@123MPH 392WHP 372WTQ I/H/E N/A-Ladies car now.
Go-Kart 35whp 29wlbft http://www.2slik4u.com/
My Garage
"People can always copy what I did first" -Jesse James
RIP Dannie FUT James
Dv8 is offline   Reply With Quote
Old 05-06-2010, 09:15 AM   #23
Reboticon
Lord Of The Clunker
Reboticon's Avatar
~Dv8
circuitry is the same for the earlier accords and civics also, just so ya know.
Old 05-06-2010, 10:15 AM   #24
~Dv8
They do appear to be identical in the RL and Legend service manuals:
Legend:
RL:
Old 05-08-2010, 09:30 AM   #25
Dv8
Life Ruiner
Dv8's Avatar
~Dv8
It works! No more having to buy from the stealership!
~Dv8
My Garage
Old 05-08-2010, 10:07 AM   #26
The Crowing
The Crowing's Avatar
Send a message via AIM to The Crowing Send a message via MSN to The Crowing Send a message via Yahoo to The Crowing Send a message via Skype™ to The Crowing
I dont think it was mentioned: Starters are different, but an RL starter CAN be used in a Legend. However, I would not recommend it be a permanent thing. It seems that the RL starter is "weaker" than the Legend's. This winter, when it got real cold out, the RL starter had trouble turning my Type II engine and getting it to start. Replaced with a proper Legend starter and no more problems. The RL starter had turned my 3.5 just fine.
Telion Pulley, Lowering Springs, and Camshaft sale:
http://forums.acuralegend.org/alumin...753#post407753
The Crowing is offline   Reply With Quote
Old 05-08-2010, 11:07 AM   #27
Nine Four One
Not on much....
Nine Four One's Avatar
Real Name: BJ
Nine Four One has a spectacular aura aboutNine Four One has a spectacular aura about
Send a message via AIM to Nine Four One
holy shit......thank you so much for taking the time to think about and post all this. one of the best threads in here. this will help anyone out thinking about doing this. just wow matt seriously well done.
Nine Four One is offline   Reply With Quote
Old 05-08-2010, 11:23 PM   #28
Dv8
Life Ruiner
Dv8's Avatar
The RL starter has a smaller coil, so it maybe weaker. Over all its a slimmer longer starter, where as the Legends is fater and shorter.
I choose the RL one over the Legend since it gave me more room to build the headers & turbo manifolds........
The RL starter is all i've ever used and its worked great.
~Dv8
My Garage
Old 06-15-2010, 09:00 PM   #29
I need some clarification on something, when you say the exhaust manifold have a different part number, different shape but compatible... does that mean that they will actually work and will bolt on w/o a problem and w/o throwing any sort of code and whatnot? If they do work w/o a problem then I just might join a certain GB..
Old 06-17-2010, 08:19 PM   #30
soloist
OCD Legend member
soloist's Avatar
Real Name: Brandon S.
Going back to my "never ending" engine swap thread, it seems the "engine stiffener" bracket from the 3.2 is incompatible with the RL motor I've got (driver's side, under the starter) the bolts are close but all 3 on top won't go in. Is this because of the revision to the mid mounts? Also, swappers save your 3.5 EGR pipe, the 3.2's don't line up indirectly b/c of the increased deck height.
average parts total for 3.5 swap??? pjslegend 2nd Gen. Legend General Discussion 4 02-22-2010 08:45 PM
3.5 swap parts soloist OEM Parts 6 02-13-2010 05:03 PM
WTB: manual swap parts!! MasTeR.LeGenD OEM Parts 12 10-03-2009 08:14 AM
5 speed tranny and swap parts stella OEM Parts 5 08-18-2009 06:37 PM
