Old 06-04-2011, 01:21 PM   #1
dbn
dbn is on a distinguished road
Default 1994 acura legend
I have a 1994 acura legend and when I come to a stop it dies on me. It cranks right back up. Any idea what would cause that?
dbn is offline   Reply With Quote
Old 06-04-2011, 01:49 PM   #2
alternator?
Old 06-04-2011, 01:53 PM   #3
Your idle air control valve (EACV or IACV) is probably the culprit. It is located to the right and directly behind the throttle body and has an electrical connection. Check the connector for corrosion which I typically see on these. If its corroded you need to clean the terminals with a thin emory board or file and clean the connector the best you can with a paper clip. Apply dielectric grease to prevent further corrosion. These valves also have a tendency to clog up on the screens which can cause the same issue.
Old 06-04-2011, 02:20 PM   #4
yeah thats what i meant to say
Old 06-04-2011, 02:22 PM   #5
4HondaOwner
Premium Gas Only
4HondaOwner's Avatar
Real Name: Kevin A
You betcha, in a different thread. The other Matt aced the test.
11-1-2019 * 94 LS Coupe 6 Speed 334,654 miles * October 2019 miles driven = 1,004
Old 06-04-2011, 03:16 PM   #6
FenrirTypeII
FenrirTypeII's Avatar
Real Name: Richie Khan
FenrirTypeII is on a distinguished road
This happened to me once, and it ended up being my battery being really low like LITERALLY DEAD. You can also check that.
What you drive matters. Some things are worth the Price. It's a Legend.
FenrirTypeII is offline   Reply With Quote
Old 06-04-2011, 03:26 PM   #7
dbn
Default dies at stop
Thanks I will check that and see if it is corroded.
FS: 1994 Acura Legend L - $650 MondiVTEC Legend 13 03-20-2010 07:54 AM
FS: 1994 Acura Legend GS 3.5 - $4500/bo MondiVTEC Legend 78 03-01-2010 07:36 AM
FS: 1994 Acura Legend LS Coupe nsxlegend Parting Out 1 11-25-2009 10:05 PM
FS: 1994 Acura Legend LS Dance4Zak Legend 6 07-14-2009 03:57 PM
