Old 10-23-2012, 10:06 AM   #1
2004ssr
1992 Acura Legend
2004ssr is on a distinguished road
Question Car will not pull in D or R and rolls in Park. GRINDING!!!!!!!!
I was pulling away from a light the other morning and all of a sudden I heard what sounded like aloud explosion and then a loud grinding sound and the car coasted to a stop. Now with the car running if I put the car in R, N, or D it starts grinding loudly and when I put it back in P at keeps on grinding until I turn the engine off. Also the wheels spin even if the car is in P. I have removed both CV axles it does the same thing. Can somebody please give me an idea of what I have going on here. I have asked several people who claim to be mechanics and have been told everything from the cv axles, to the differential, to the tranny. PLEASE HELP.
2004ssr is offline   Reply With Quote
Old 10-23-2012, 10:18 AM   #2
sounds like what has happened is the extension shaft (which connects the trans to the diff) has failed.
Old 10-23-2012, 10:20 AM   #3
2004ssr
1992 Acura Legend
How do I replace the extension shaft?
Old 10-23-2012, 10:22 AM   #4
2004ssr
1992 Acura Legend
or I should ask how I can determine if it is the extension shaft and if so how can I replace it?
Old 10-23-2012, 10:27 AM   #5
+1 def sounds like the extension shaft or the differential.
http://www.atfinley.com/service/inde...&z=2690&r=0359
The extension shaft is located on the pass side of the trans near the bell housing, it is behind a rubber cover and uses a 36mm socket to remove the sealing bolt, and then you will need a special tool to pull the extension shaft....
Old 10-23-2012, 10:35 AM   #6
2004ssr
1992 Acura Legend
Is that the bolt that takes a 1/2" drive ratchet to take off? How can I determine if that is the problem? I really need to get my car going today and I don't have a clue!!!
Old 10-23-2012, 10:37 AM   #7
2004ssr
1992 Acura Legend
To remove that nut do I turn it clockwise or counter clockwise?
Old 10-23-2012, 10:39 AM   #8
Lefty loosey, righty tighty
Old 10-23-2012, 10:44 AM   #9
2004ssr
1992 Acura Legend
I just wanted to make sure. I have tried to remove it but its extremely tight. I don't want to strip it.
Old 10-23-2012, 10:48 AM   #10
have a breaker bar or a pipe you can slide over the handle of the ratchet for a little extra leverage? That bolt is on pretty tight....
3.2l, axle, cv axle, differential, extension shaft, grinds, legend, transmission
Krispy Kreme Tuesdays 1-24-2012 SoCal rolls deep T-Clyde Other Cars 17 01-31-2012 01:59 PM
grinding in reverse dbn 2nd Gen. Legend General Discussion 7 05-14-2011 02:18 PM
This WILL make your day. Fake Rolls (Chrysler 300) being called out R_R4 The Water Cooler 20 03-18-2011 07:40 AM
Rear driver side window Only rolls up what could it be? Romero88 2nd Gen. Legend General Discussion 2 01-14-2010 06:37 AM
grinding noise? Wayne-A-Ferd 2nd Gen. Legend General Discussion 2 12-09-2009 06:06 AM
