Old 04-05-2011, 11:25 AM   #1
LegenDinTheMaKing
LegenDinTheMaKing is on a distinguished road
Default Could use some help with my new 1991 "GS".
I hope you all got the joke in my title. So I went ahead and dropped in a tranny and type 2 engine from a 93 LS coupe into my 91 sedan. I am still using the ECU from my 91 sedan. Because of the fact that the engine that I was dropping in had it's harness cut, my mechanic said he had to do some re-wiring from my original harness. The car starts up fine. But the check engine light stays on. Also when I drive the car and press the gas to excelerate it takes way longer than before to get to 3rd. It stays in 2nd and slowly crawls up to 3rd even when I am flooring it. Before with my type one whenever I hit the gas I would be in 3rd within a blink of an eye. Would any of you awesome people happen to know what could possibly be the cause?? Your replies would be greatly appreciated.
LegenDinTheMaKing is offline   Reply With Quote
Old 04-05-2011, 11:42 AM   #2
I'd say move #1 would be for you to get us a code reading. It's all guesswork without that.
I have little alarms going off when I hear "cut harness" and "re-wiring". Perhaps you know or can find out specifically what was involved for us.
Also I don't think a T2 engine is going to run very well on the T1 maps in your ECU. Those cams have a lot more dwell and there is probably some other stuff too.
Old 04-05-2011, 12:41 PM   #3
type 1 and type 2 tranny's have differences. you may need a type 2 ECU or have your type 1 chipped by Telion or sr5guy.
But I agree with Rich, read the code from the ECU first before you dive into things further.
Old 04-05-2011, 12:48 PM   #4
Team LR
UndaUGal
Team LR's Avatar
Team LR is on a distinguished road
u need the type 2 ecu to control the engine an tranny properly n that re wire sound like a load of bs cuz type 1 n 2 use the same harness beside have a tcs wire for the type 2 which u dnt have in a 91
Team LR is offline   Reply With Quote
Old 04-05-2011, 01:08 PM   #5
Actually there's more than TCS different in the two harnesses... but let's see what he can find out for us.
Old 04-05-2011, 01:29 PM   #6
LegenDinTheMaKing
Thanks again guys. So he said that the cam sensors were rewired. Apparently there is supposed to be a male and a female plug but mine had two male plugs so he took a female one off of the harness that was cut and wired it onto my 91 harness. And if i wind up having to get a new ecu does it matter if it comes from a 1994-95 GS Sedan or 1993-95 LS coupe? Does it matter? If any of you happen to know that exact part number that would great to. I could be wrong but I think it's 37820-PX9-A68 for the GS.
Old 04-05-2011, 01:35 PM   #7
He was too lazy to change the cam position sensor from your old motor, so instead he doubled his work and hacked up your harness. hgeez:
Unless you have the code from the CEL, we can't really help you - its kind of like calling the parts store and not knowing what kind of car you need parts for.
Find out whats going on with the CEL first, you can use any automatic type II ECU.
Old 04-05-2011, 02:25 PM   #8
Jonslegend
Ive Got 2nd Gear!!!!
Jonslegend's Avatar
Real Name: Jonathan Roose
Jonslegend will become famous soon enough
I have one
It's not Gold, It's Cashmere
Jonslegend is offline   Reply With Quote
Old 04-05-2011, 02:57 PM   #9
LegenDinTheMaKing
Sorry but what's the CEL?
Old 04-05-2011, 03:10 PM   #10
Check Engine Light
Per Q - you will need this likely:
LegendWiki - G2: DIY: Diagnosis: Pulling Codes
ecu, sedan, swap, type 2, type ii
"Growlll" during acceleration then "Wooo" during deceleration? Vaulium 2nd Gen. Legend General Discussion 4 02-10-2011 12:27 PM
Rear chrome "Acura" and "A" logos BluBrett OEM Parts 2 11-15-2010 01:12 PM
Is there a public "track" that I can "test" my Legend's handling at? BluBrett The Water Cooler 10 11-12-2010 12:18 AM
"Theoretical" question involving slight "self scalping" by accident... Reboticon The Water Cooler 44 08-12-2010 09:46 AM
"Parts Wanted" and Legends" for sale sections ActionJackson Feedback and Requests 2 06-04-2009 06:16 AM
