Old 09-01-2009, 02:38 PM   #21
alittlethin
alittlethin's Avatar
alittlethin will become famous soon enough
You can re-weld that with a simple stick welder and some 316 - 3/32" rod. 304 stainless steel does rust, it just takes awhile. The higher the number (in general, there are some ductility factors) the less susceptible to corrosion it is. That would take about 5 minutes to fix.
"Where the F.. is the, "SWEET SPOT !!??",... I can't find it??
Come on man, don't take it so serious. It takes a lot of comitment and pride to throw money into something that will never yield a 16th back.
~Dv8
alittlethin is offline   Reply With Quote
Old 09-01-2009, 02:42 PM   #22
alittlethin
Originally Posted by T-Clyde View Post
uuuhhh, seeing where its cracked. and havin a background in welding. i don't agree.. YES that bracket would have helped. i have no arguement there.
HOWEVER. anything that cracks right at the weld. or right next to it. is inferior and poorly welded.
i had NO opinion on OBX until seeing HOW they cracked. not THAT they cracked.
I agree, on pipe fitting welds the stongest point of the pipeis in the weld. Without seeing the whole weld my guess is that it started to crack because of dishing out in the pipe material. This is due to having the amps too high in the welding process.
~Dv8
Old 09-01-2009, 07:03 PM   #23
forevralegend
3.2 FTW
forevralegend's Avatar
Real Name: Eric
forevralegend is on a distinguished road
looks like you were leaking oil on them for quite some time, I'm sure that didn't help them last.. there shouldn't be much stress on the headers to begin with. Make sure you fix the leakage problems before you put a fresh set of expensive headers on your car.
custom 2.5" mandrel bent exhaust, CAI,web cams, p&p heads, tb bypass,egr block, 5spd clutch/fly, poly 80a mounts, type 1 crank pulley, Premium OBX headers, custom y-pipe, SR5guy Chip, 6spd trans, prelude strut bar, Addco sway bars, custom tie bars, ksports
243.3 hp 197.7 ftlb N/A dynapack 232.8 hp 204.0 ftlb N/A dynojet 10/19/07
13.657 1/4 mile @ 101.861 mph & 1.934 60' NA
forevralegend is offline   Reply With Quote
Old 09-01-2009, 07:11 PM   #24
i wasn't aware they made expensive headers for our cars. its the oil pan gasket. i believe its actually the oil pan causing the leak. if i pull the motor out to fix the leak, i don't think i'll be putting this motor back in. hgeez: so i'll keep leaving my mark in people's driveways and garages.
Old 09-01-2009, 07:14 PM   #25
GrtOutdoorsAZ
Well Wisher
GrtOutdoorsAZ's Avatar
RICEY
J/K!!!!!
Damn Alex, I guess I better get under my GS and inspect my headers too. One advantage I have is the dry weather here though....
'94 GS 6MT KA7
Sig by DG
Old 09-01-2009, 07:21 PM   #26
terragotti
Need Power
terragotti's Avatar
terragotti is on a distinguished road
Keep leaving your mark huh? lol
www.368musicgroup.com
terragotti is offline   Reply With Quote
Old 09-01-2009, 07:22 PM   #27
haha yea, just ask jen
Old 09-01-2009, 07:52 PM   #28
forevralegend
3.2 FTW
Real Name: Eric
I'm talking about the new headers that are being produced. If you decide to get them, you wouldn't want to destroy the nice stainless steel by leaking oil on them.
Old 09-01-2009, 10:15 PM   #29
EXACTLY! I thought bang for buck, the OBX's were ok, if they would last. Its not that they cracked, its WHERE they cracked and after how long. Dont get me wrong, any stress or added load would speed this process up, but this also isnt the first instance of these headers cracking along the welds.
Old 09-01-2009, 10:22 PM   #30
Russian
Russian's Avatar
Russian will become famous soon enough
Originally Posted by eBay ad
Don't settle for the cheaper headers on eBay which are known to crack over time due to cheap welding, thin flanges, and very thin wall thickness. Also comes with a lifetime warranty from manufacturer defects.
Russian is offline   Reply With Quote
cracked headers, exhaust, manifold, obx, obx headers
OBX muffler, flowmonster cat and 3.5 flyby and pics Telion 2nd Gen. Legend Performance Enhancements 28 11-19-2010 11:28 AM
Best Pics so far I think! Roger Second Gen Legend Gallery -- 1991 - 1995 51 07-09-2009 12:23 AM
Pics of my GS Ian Second Gen Legend Gallery -- 1991 - 1995 20 06-30-2009 01:13 PM
old meet pics T-Clyde Meet Photos 5 06-27-2009 08:37 PM
Some pics of the GS.... samblaze Second Gen Legend Gallery -- 1991 - 1995 18 06-09-2009 03:11 PM
