Old 09-11-2011, 06:44 PM   #1
GreenHornet Legend
GreenHornet Legend is on a distinguished road
Default 3in exhaust on a mostly stock engine
I was looking for an answer but I think I already now it. I was wondering if I can put a 3in exhaust pipe from where the pipes join together all the way back to the muffler? I was wondering because I plan on turbo charging the car later but I don't really know the science behind the exhaust. Is it ok to do this or will I lose power doing this to a stockish engine. I would then modify the pipe later to accommodate the turbo.
Synergy Green Legend
GreenHornet Legend is offline   Reply With Quote
Old 09-11-2011, 06:53 PM   #2
Gascan
Less doom less gloom
Gascan's Avatar
Real Name: Michael K.
Seems to me that you're working on this backwards. Start with turbo then modify the exhaust to accommodate the turbo.
Yes, you'll loose major power with a stockish engine.
Old 09-11-2011, 07:02 PM   #3
Geneva_Jee
Gold Member
Geneva_Jee's Avatar
N/A engines need back pressure...a 3in exhaust on a stock motor will make it lose power
Old 09-12-2011, 02:40 AM   #4
hustlav6
hustlav6 is on a distinguished road
pipes length and diameter are calculated to help empty the cylinders at exhaust stroke, if you alter any of exhaust dimensions without checking (by calculations) what effect you achieve - sonic or dynamic, you will be surprised that your engine seem to give you less power than it should, probably you will gain some hp in certain (probably high)rpm range, but it will be useless in daily driving, generally in n/a engines the bigger exhaust piping is, the higher engine revs would be needed to use gained power
hustlav6 is offline   Reply With Quote
Old 09-12-2011, 03:06 AM   #5
T-Clyde
Canter-Buried Alive
T-Clyde's Avatar
Real Name: Tommy
Where's grumpysteelman when you need him? Smh
Hustla is on the right track, but grumpy is soo good at explaining the back pressure myth.
OEM Parts for Sale
Maintenance > Modification
Old 09-12-2011, 06:34 PM   #6
legend93g2
Improving WHP
legend93g2's Avatar
This +1
legend93g2 is offline   Reply With Quote
Old 09-12-2011, 06:38 PM   #7
GreenHornet Legend
So the same reasoning applies to headers?
Old 09-12-2011, 06:52 PM   #8
ManOfBusiness
My Penis Has A Name
ManOfBusiness's Avatar
ManOfBusiness is a jewel in the roughManOfBusiness is a jewel in the roughManOfBusiness is a jewel in the roughManOfBusiness is a jewel in the rough
Cars with small displacement lose bottom end torque because they have to overcome the pressure of slower moving exhaust gasses in large diameter piping.
Larger displacement engines capitalize on a larger exhaust setup because as someone said previously their engines can use this increase in potential airspace, with more displacement, you have more exhaust gasses which increases the use of the gained potential air space.
Realistically, and engine under 3 litres N/A would not benefit from an increase in exhaust or header piping over stock, however its the gain in increased flow potential due to more efficient pipe flow design.
-Some things never change, and some things do-
ManOfBusiness is offline   Reply With Quote
Old 09-12-2011, 07:18 PM   #9
T-Clyde
Canter-Buried Alive
T-Clyde's Avatar
Real Name: Tommy
I have to disagree, and this is directly related to accords of my generation. They all share the same 2.2 l block, but the dx and lx have smaller exhaust and a cast manifold, where as the ex has a tubular manifold and 1/4 larger piping all the way back, stock for stock the ex has 10 more hp and the only differences are the larger exhaust and slightly larger intake mani.
You don't lose torque, you simply move the peak torque higher in the powe band.
OEM Parts for Sale
Old 09-12-2011, 07:29 PM   #10
ManOfBusiness
My Penis Has A Name
Great... thanks for the input... please note I said bottom end torque. and whether you realize it or not, you're agreeing with me.
3 inch pipe, big pipe, exhaust, horsepower, turbo
My Stock IS-F Dv8 Videos 28 08-03-2012 02:39 PM
Engine Replacement... What to change while the engine is out? pacallen 1st Gen. Legend General Discussion 5 07-31-2010 08:52 PM
stock exhaust manifold question uniquelegend 1st Gen. Legend General Discussion 4 12-28-2009 12:50 PM
engine crank and won't start engine check light Legend95 2nd Gen. Legend General Discussion 0 12-22-2009 05:59 AM
stock exhaust + high flow cat sound? hotstartup 2nd Gen. Legend General Discussion 4 08-25-2009 06:00 AM
