Old 11-08-2019, 11:41 PM   #1
paulo57509
paulo57509's Avatar
Default Door Panel Screw Grommets
Frankly, I'm getting to that age where even though I've had the door panels off countless times, I don't remember what they look like.
I "think" some of them have square heads, some are round, some are slotted and fit into square holes in the sheet metal; maybe for #4 or #6 sized screws.
A lot of grommets are long gone and I've been using drywall anchors with so-so success; these are round and don't work well in square holes.
I know clips and fasteners "might" have them, but their catalog lists a bunch of them and I have no idea what to order.
https://www.clipsandfasteners.com/Default.asp
I've tried getting the Honda part number and searching that way but have had no success.
I'm almost to the point of using rivet nuts and machine screws. Which might not be a bad alternative since the lock actuators, rods and window regulators are staring to show their age and require frequent access.
Can anyone point me in the right direction? Thanks.
'87 L-Coupe 5-Speed
Stock; Few Mods
444K Miles - original engine and drivetrain.
Old 11-17-2019, 12:36 PM   #2
paulo57509
paulo57509's Avatar
FWIW, the Honda part numbers for these screw "grommets" are:
1. 90674-SB0-000, Grommet, Tapping Screw
2. 91561-SE3-003, Grommet, Screw 6mm
These are the only screw grommets I could find on the exploded parts diagram and parts list.
As best I can tell, these are still available from the dealer.
No. 1 above is also available from Clips and Fasteners (www.clipsandfasteners.com); search for the superseded part number, 90672-671-811.
Best I can tell from the basic line drawings of the parts, No. 1 is the round face, square shank grommet; No. 2 is the square face, square legs grommet.
Quantity per door?
'87 L-Coupe 5-Speed
Stock; Few Mods
Old 12-04-2019, 04:44 PM   #3
paulo57509
paulo57509's Avatar
FWIW, I received the (Honda P/N) 90674-SB0-000 grommets from Clips & Fasteners.
I already tried looking for the Auveco part number to buy direct. They only sell through distributors. Shop wisely and don't get bent over - a seller on ebay wants $20 for the same box. Clips is asking ~$5 plus shipping.
'87 L-Coupe 5-Speed
Stock; Few Mods
FS: 94-95 LEGEND REAR PASSENGER DOOR INSIDE DOOR PANEL tito1228 OEM Parts 0 05-28-2014 12:33 PM
WTB: Type F ('95 coupe) Interior Door Screw Cap milobmx OEM Parts 5 05-12-2014 02:29 PM
WikiDIY: Door Panel Removal Quaraxkad Second Generation Legend (1991 - 1995) 2 06-15-2010 11:25 AM
how should i remove it? ( under door panel) Legend95 2nd Gen. Legend General Discussion 15 12-31-2009 03:19 AM
Help removing door panel kanichi 2nd Gen. Legend General Discussion 11 08-12-2009 04:54 PM
