#1 |
2004 Carbon Gray 3.5
What are my options to upgrade the brakes on the Acura. I've done a little research, but haven't come up with too much yet, so I figured I'd ask the Acura gurus.
So, I'd like to upgrade the brakes and such on the car, but I don't want to spend a fortune doing it. I'd love to pick up a set of the 3G TL BREMBOs but also curious to see what else it out there and I'd like to upgrade the rotors as well and stainless steel lines are easy to install, but wanting to get people's opinions about those as well. I figured since I'm about to paint the car and do the whole front end conversion, and install the new wheels, I might do it all now including brakes
I'm your Loving Neighborhood Asshole! 2004 Carbon Grey Metallic Acura 3.5RL with Navigation... the last of the good RLs |
#2 |
Really... no one?
#3 |
RIP Fut-diesel
well what do you want to step to? anything acura is going to be Custom, But there's some companies out there with some relatively cheap BBKs
#4 |
I meant using parts from other Hondas / Acuras and making a custom setup.
Such as I read the other day the Odyssey rotors are the same as RL rotors and such and could I use a 3G TL Brembo kit on my RL... Things like that.
#5 |
RIP Fut-diesel
either you could upgrade your calipers to the EDM KA9's with dual pistons and swap in the 99-04 Big Rotor with the bracket for it, or you can just swap in the bigger rotor... gotta make sure to get the bracket for your caliper though. 12" rotors and such.
MDX rotors are the same as the RL rotors apparently. You should try the EDM calipers, if you can get them. I don't now if JDM used twin piston calipers or not. |
#6 |
What bracket are you talking about?
As for the EDM calipers, I'll look into them. Thank you again!
#7 |
How much you looking to spend?
Its gonna cost a good chunk for custom. If your lucky nd thr TL brembos will bolt on, then it'd be a matter of finding an oem rotowithe the correct diameter and offset.
#8 |
#9 |
^^^ WELL... Balls.
And I don't want to break the bank, but a couple hundred $500-$700 would be fine.
#10 |
Real Name: Matt
you ever figure anything out, as far as larger OE brakes?
Thread Tools | |
Display Modes | |
Build thread for 2nd gen Lengend K sport coilovers on a 1st gen RL... | CarbonGray3.5 | 1st Gen. RL Performance Enhancements | 30 | 04-26-2013 05:38 AM |
DIY: 1st Gen Acura RL Instrument Guage Cluster LED Bulbs (thnx to 97RLer) | G3Silver | First Generation RL (1996 - 2004) | 4 | 08-05-2010 03:36 AM |
1st Gen RL Alternator needs | DrDave | 1st Gen. RL General Discussion | 3 | 01-15-2010 08:01 PM |
4piston 2nd gen RL calipers on 1st gen RL | OLD_HATCH | 1st Gen. RL Performance Enhancements | 16 | 11-06-2009 02:52 AM |
