Old 02-23-2012, 02:15 AM   #1
LilRennagade
Real Name: Bobby
LilRennagade is on a distinguished road
Angry 92 Legend sedan idle problem
So my legend sat for a long while ( loooong story lol ) but in the process of having everything replaced at the shop and driving it 1-it runs "ok" 2-it shifts really rough and 3-it refuses to idle right It seems like right when the thermostat opens and the idle is supposed to come down it starts this cycle of high idle low idle high idle low idle. It's like it goes from cold idle to warm idle and back and forth and when it's in gear (reverse or drive) it doesn't happen. Just at idle BUT it does die sometimes when coming to a stop also. The mechanic said it's because of a vacuum leak in the intake system housing but I wanted another thought on it if someone else had something similar happen.
So basically wondering thoughts on getting the car running a little smoother and shifter smoother after sitting so long and if it's a vacuum leak that could be causing the inconsistent idle and dying when stopping. Any thoughts would help!
LilRennagade is offline   Reply With Quote
Old 02-23-2012, 02:19 AM   #2
Sounds like you have air in your coolant system. Bleed it and you should be fine. If it happens again then you a leak in the system.
Old 02-23-2012, 02:26 AM   #3
LilRennagade
Real Name: Bobby
Its been bled and thats what confuses me so much because for the longest I always thougth it was air in the system but its been bled or someones tried like 4 different times. It does have a tear in the hose that goes from the air filter to the throttle body and it does have a leak but would that really cause it to die?
Old 02-23-2012, 03:02 AM   #4
When you bleed the system is the heat on high?
Old 02-23-2012, 01:04 PM   #5
LilRennagade
Real Name: Bobby
Yeah it is, but thats another thing, the heater wont blow hot.......im so confused!
Old 02-23-2012, 02:00 PM   #6
ari_one
MeltingInTheSun
ari_one's Avatar
Sounds like you may have a blockage in your heater core, that is why it is not getting hot and the bleeding is not working completely.
Old 02-26-2012, 09:09 AM   #7
Donald
Real Name: Donald R
Donald is on a distinguished road
All good advice. Also, vacuum leaks will do it everytime. We bled ours and finally had to replace the idle control valve along with the EGR. Took some work but it runs like new. 91 Legend, 374K. Love the car. Don
Donald is offline   Reply With Quote
idle, leak, vacuum
95 Legend Sedan Rough Idle/Sway at about 30 mph ahwatukeedj 2nd Gen. Legend General Discussion 11 03-01-2012 08:10 PM
Strange Idle problem Donald 2nd Gen. Legend General Discussion 12 11-27-2011 09:21 AM
idle problem any ideas!?!?! Ken 2nd Gen. Legend General Discussion 3 02-09-2011 10:54 PM
Idle problem, almost stalls it's self... LegendaryAffinity 1st Gen. Legend General Discussion 50 02-14-2010 10:26 PM
Steve's Idle Adjust Screw Problem DallasLedge89 1st Gen. Legend General Discussion 2 09-17-2009 11:51 AM
