Old 12-30-2011, 06:04 PM   #1
JayRuns
Rhode Island Based
JayRuns's Avatar
Real Name: Jason A
JayRuns is on a distinguished road
Default Stock Speaker Performance
Hey everyone, I have a '91 L coupe that's completely stock down to the radio. A few months ago I replaced the blown factory front speakers with some nice 6.5" Pioneers. The sound quality isn't too great from the front end, so today I grabbed some minty fresh speakers (Alpine) from a '99 RL in the car graveyard. The inside of this whip was immaculate, and the factory speakers were in great condition ($5 a piece, too). So my question is whether or not putting Acura factory speakers back in will create a better sound?
Thanks fer the help, guys!
JayRuns is offline   Reply With Quote
Old 12-30-2011, 07:12 PM   #2
kongbuiltt
Dissizit!
kongbuiltt's Avatar
kongbuiltt is on a distinguished road
Check the impedance ohm rating. The aftermarket speaker(s) generally higher and Bose systems typically run 2 ohms so connecting the alpines non specific to the stock factory system will cause lower volume and mudded sound production. Others can chime in.
ALSO, in this case I would use 2 ohm CDT audio replacements with a crossover. There are are members here that are more knowledge in this area and can advise better.
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
Simple enough.
kongbuiltt is offline   Reply With Quote
Old 12-30-2011, 07:20 PM   #3
JayRuns
Rhode Island Based
JayRuns's Avatar
Real Name: Jason A
Alright, that makes sense. I have a non Bose head unit right now and the speakers are 4 ohm, does that sound about right?
Old 12-30-2011, 08:35 PM   #4
Well a "l" model would have had non premium sound system so a 4ohm system and not a 2ohm.
Possibly the pioneer speaker was just too powerfull for the oem.head unit
Typically the bose system oem.from our cars sound really good imo.
Also bose sells new replacement oem speakers for $40 a POP. Both 2omh and
4ohm speakers.
Old 12-30-2011, 08:43 PM   #5
kongbuiltt
Dissizit!
kongbuiltt's Avatar
You should be fine. If utilizing an aftermarket harness. There's no bypass needed and the power from an aftermarket head unit should power the interior speakers just fine. Head unit power is rated in RMS. Check speaker max wattage rating, which in your case shouldn't be an issue.
There are some great threads in the audio section of the forum that break down sound dampening, preferred speakers, SQ, etc.
I suggest you familiarize yourself with some basics if you're intending for a clean setup as most members here have upgraded systems with a ton of power. Not sure of your intent; whether you are slowly building out a system or replacing what's needed for the time being there is a lot of intel to be absorbed. And, you can always ask for help... That's what I do.
Simple enough.
Old 12-30-2011, 09:03 PM   #6
JayRuns
Rhode Island Based
JayRuns's Avatar
Real Name: Jason A
ah right thank you! I've had my Legend for about a year now and it was owned by two old ladies before me, so everything is completely stock and I'm hoping to keep it that way. The stock HU isn't too bad, I just want to make sure I get the most out of it. Alperovich, you're prob right about the speakers being too powerful. Hopefully I'll be able to make the swap tomorrow if the weather cooperates. Thanks again for the help, guys, I'll be lurking the audio threads for sure
Old 12-31-2011, 08:44 AM   #7
gsdreams
Real Name: Larry
gsdreams is on a distinguished road
There is a problem here. As far as I know, all RL models had the Bose Premium. It even appears that way in the Factory Service Manual, but those aren't always accurate.
The Bose Premium system is a 2 Ohm setup, not 4 Ohm. Those speakers you pulled from the RL are probably going to be 2 Ohm and your system is 4 Ohm..................
Originally Posted by Legend37 View Post
All I got to say is, once you drive a Legend, you fall in love forever.
gsdreams is offline   Reply With Quote
Old 12-31-2011, 09:01 AM   #8
JayRuns
Rhode Island Based
JayRuns's Avatar
Real Name: Jason A
I just checked the speakers I pulled and it says "Alpine SA1HN440" 4 ohms-max 30w Made in Japan. Everything in the RL was still stock as well. Does anyone know how well the stereo setup in a '99 RL was?
Old 12-31-2011, 09:04 AM   #9
gsdreams
Real Name: Larry
That RL speaker should have "Bose" with a part number on it. I suspect if you check the part number you will find it's a 2 Ohm speaker for the Bose Premium System. The RL Stereo system is the upgraded version of what the Legend LS has.
Old 12-31-2011, 09:44 AM   #10
It says 4 ohm right on the speaker.
So either it was a replacement speaker in the RL, or not every RL came with Premium Bose at 2ohms
If the speaker has 30w max (not RMS) I wouldnt get your hopes up Jay. It will be a fair and cheap replacement, but dont expect crazy awesome sound.
acura, legend, speakers, stock
what is this speaker for does anyone know? Kev711 2nd Gen. Legend General Discussion 11 04-25-2011 07:18 PM
PERFORMANCE MUFFLER LEGO 1st Gen. Legend Performance Enhancements 35 04-13-2010 04:25 PM
Performance Chip killaswa6 "Not Mine" 0 11-19-2009 12:52 PM
Performance help please!!! shortynereim 2nd Gen. Legend Performance Enhancements 14 10-13-2009 06:42 PM
