Old 09-08-2011, 04:19 PM   #31
Last time I did it, I just put in the bolts and it started to seal it right away. Make sure you didn't damage the pins.
Old 09-08-2011, 04:40 PM   #32
kitchwatembo
shot caller
kitchwatembo's Avatar
im not sure i know which pins you mean
My 87 Legend L Sedan
-jason
Old 09-08-2011, 04:56 PM   #33
There's 2 pins that is between the engine block and tranny.
Old 09-08-2011, 05:29 PM   #34
stephen
They are dowels and there should be two of them. If they are lined up and the transmission is all the way up on the back of the block all the bolts should go up.
I've installed the bolts in the following order. Three left side of transmission
(toward front of car). One on right side going in from the engine side. Starter
bolts. Trans mount bolts.
If you are having trouble with the rear trans mount bolts, put in the upper one that goes in from the trans side first and then put in the bottom ones. If they don't want to line up move the engine/trans around some till they do.
Old 09-10-2011, 08:22 PM   #35
kitchwatembo
shot caller
Default Finished!
Well I finally finished everything up and couldn't be happier. Special thanks to Stephen, James, Tinton, egamI_rorriM, and my hammer for helping a bunch.
and finally a picture that isn't in some hot dirty garage.....
Its great to be back outside and have my wheels back.
-jason
Old 09-10-2011, 10:55 PM   #36
Old 09-12-2011, 12:52 AM   #37
egamI_rorriM
egamI_rorriM is on a distinguished road
Send a message via MSN to egamI_rorriM
Glad to hear you were able to put it back together.
1987 Legend Coupe 5spd
egamI_rorriM is offline   Reply With Quote
Old 09-12-2011, 02:04 PM   #38
stephen
Glad we could help.
The car looks very clean and well maintained.
clutch, cylinder, leak, slave
clutch slave cylinder replacement? hotstartup 2nd Gen. Legend General Discussion 17 06-28-2011 09:50 AM
Clutch master cylinder and slave cylinder Stillmatic OEM Parts 1 11-29-2010 02:51 PM
Question about clutch slave mastercylinder MasTeR.LeGenD 2nd Gen. Legend General Discussion 1 11-02-2009 03:13 PM
6 spd clutch boot leaking. hotstartup 2nd Gen. Legend General Discussion 7 10-10-2009 11:26 PM
FS: G2 5mt swap, flywheel, clutch, diffy, mc/slave whole shabang MXHalofan OEM Parts 9 09-29-2009 09:48 AM
