Old 08-18-2011, 04:35 PM   #21
kitchwatembo
shot caller
kitchwatembo's Avatar
Originally Posted by egamI_rorriM View Post
If for some reason you need a clutch fork please see my other thread. I tried ordering an OEM fork from various places and it's not available any longer but i found a compatible replacement from Honda Accord/Prelude that will work.
http://forums.acuralegend.org/showpo...8&postcount=14
good call my man. my culprit was a broken fork. my only question to you is, how did you attach the spring clip to the prelude fork?
My 87 Legend L Sedan
-jason
Old 08-24-2011, 01:50 PM   #22
egamI_rorriM
egamI_rorriM is on a distinguished road
Send a message via MSN to egamI_rorriM
With the new style fork it no longer uses that riveted spring clip like the stock one. Instead it uses a wire clip that goes into slots cut into the fork. You will need both the clip and fork which are separate part numbers.
Fork P/N: 22821-PX5-000
Spring Clip P/N: 22835-PX5-A00
First you put the wire clip onto the fork and just put the fork on top of the pivot bolt and press down. the wire clip is flexible so it will separate and then pop down under the pivot bolt head.
Here is where i found some of the info for the fork swap. It shows the old and new fork as well as it installed.
http://www.preludezone.com/3rd-gen-h...ease-fork.html
1987 Legend Coupe 5spd
egamI_rorriM is offline   Reply With Quote
Old 08-24-2011, 01:55 PM   #23
kitchwatembo
shot caller
ha I realized how stupid my question was when I got the parts and put them together.
just waiting on a new clutch kit to put it all back together.
-jason
Old 08-24-2011, 02:02 PM   #24
egamI_rorriM
lol, it happens.
In what way was your fork broken? one of the tangs on the spring clip on mine broke which i think after years of rubbing broke off the head of the pivot bolt.
Mine kind of looked like this
Old 08-24-2011, 03:24 PM   #25
kitchwatembo
shot caller
my clip was still there, just starting to flake away. but my real issue was the big ass crack in the fulcrum point. ~230k miles
-jason
Old 08-24-2011, 10:52 PM   #26
filmshoot
Kierkegaard binge
filmshoot is on a distinguished road
that fork took a beating - were you racing it?
I'm selling some decent and somewhat rare coupe parts here--->
http://forums.acuralegend.org/filmsh...ight=filmshoot
filmshoot is offline   Reply With Quote
Old 08-25-2011, 09:37 PM   #27
Damn man, easy on your shifting lol.
Old 08-28-2011, 02:15 PM   #28
kitchwatembo
shot caller
haha i have fun from time to time, but overall im a pretty mellow driver
-jason
Old 09-08-2011, 04:09 PM   #29
kitchwatembo
shot caller
Default transmission re-installation
after a DOA clutch kit mishap and other various problems, im putting everything back together.
tranny is on the engine, but i cant get all the bolts to line up. i can get every one except the two rear engine mount bolts. Ive been messing around with loosening and even removing most of the bolts but cant see to move the tranny back the necessry 1-2 cm towards the rear of the car.
can anyone who has done this job tell me the order they put tranny bolts in? i was just doing the FSM removal order in reverse.
-jason
Old 09-08-2011, 04:16 PM   #30
egamI_rorriM
I had to use a floor jack and wood 2x4 to brace the bottom of the motor to adjust it around so i could get the bolts in. i didnt tighten any of them down until i had them all started, except for the starter motor bolts which i did last. I did my car in my buddys shop with a hydraulic lift so i was able to stand up under the car which really helped a lot.
clutch, cylinder, leak, slave
clutch slave cylinder replacement? hotstartup 2nd Gen. Legend General Discussion 17 06-28-2011 09:50 AM
Clutch master cylinder and slave cylinder Stillmatic OEM Parts 1 11-29-2010 03:51 PM
Question about clutch slave mastercylinder MasTeR.LeGenD 2nd Gen. Legend General Discussion 1 11-02-2009 04:13 PM
6 spd clutch boot leaking. hotstartup 2nd Gen. Legend General Discussion 7 10-10-2009 11:26 PM
FS: G2 5mt swap, flywheel, clutch, diffy, mc/slave whole shabang MXHalofan OEM Parts 9 09-29-2009 09:48 AM
