Old 08-21-2012, 05:09 PM   #1
ZThompson
Legend enthusiast
ZThompson's Avatar
Real Name: Zack
ZThompson is on a distinguished road
Default Paint touch up on center caps
Has anyone here had any luck touching up the paint on their OEM center caps? Mine are a little scratched/chipped from rocks and I'd really like to fix them if at all possible. Some type of silver metallic paint was what I had in mind, but if anyone else has done differently I'd like to hear how. Thanks!
ZThompson is offline   Reply With Quote
Old 08-27-2012, 01:34 PM   #2
if you have some skill level you can re paint them, i did it to mine years back with black logos everything.
Old 08-27-2012, 01:49 PM   #3
0S1R1S
0S1R1S is on a distinguished road
Try the Duplicolor Metalcast paint. Just remember, to prep the surface you're going to have to scuff it a little with 320 grit paper. Also, use a clear engine enamel 10-15 minutes after the final coat, lightly, to keep the rock chips from ruining your day in the future.
0S1R1S is offline   Reply With Quote
Old 08-30-2012, 03:05 AM   #4
I made a DIY once maybe on .com or .org about redoing the center caps.
Might still be listed in the diy section.
cap, center, paint, touch up
FS: Loads of 1994/1995 coupe parts ( foglights, floormats, touch up paint ) Tippey OEM Parts 13 07-03-2011 11:41 AM
04 tl rim center caps Akito OEM Parts 3 05-12-2011 10:07 AM
FS: GS center caps 94legendcpe OEM Parts 17 01-14-2011 05:35 PM
Touch-up paint BluBrett The Water Cooler 11 01-11-2011 02:02 AM
Center Caps Fatal OEM Parts 7 10-31-2010 04:41 PM
