Old 06-08-2011, 03:15 PM   #1
legend93g2
Improving WHP
legend93g2's Avatar
Default Where is the A/C filter?
Theres no DIY on this and i couldnt find any threads, but IIRC i remember someone doing this. An even saw pics of ppl customizing new filter bc of how expensive ours is.
ActionJackson, i could of sworn i saw you make one.
Please chime in for any help.
I removed the glove box bc i wanted to make sure my blow motor, fan, etc was working. An it is.
But where is the filter? Or better yet why isnt the A/C blowing through my vents as it should? My guess is the filter is so clogged air cant pass through.
This is what i see.
Thanks for any help guys!
legend93g2 is offline   Reply With Quote
Old 06-08-2011, 03:27 PM   #2
the filter is behind the that green and gray plug. There is 1 or 2 bolts holding that plate on.
Check out this link
http://www.acuralegendwiki.org/index...ing_air_filter
Old 06-08-2011, 03:39 PM   #3
Tippey
Pony
Tippey's Avatar
Real Name: Austin
The filter is almost always between the blower motor and evaporator coil
Old 06-08-2011, 05:32 PM   #4
legend93g2
Improving WHP
legend93g2's Avatar
Check out this link
Thank you very much sir! That link couldnt be better.
repped for such a quick repsonse and great info!
Thanks tippey.
Old 06-08-2011, 05:54 PM   #5
There's 2 phillips head screws holding that metal plate in that the two plugs
are attached to. Remove those and pull the metal plate off and the filter is right there.
Old 06-08-2011, 07:36 PM   #6
Good looking out Dreams and ActionJackson. They told you 100% correct. I just hope your metal bracket's edge wasn't "finger unfriendly". I didn't quite cut myself when I did mine but that edge was close to being as sharp as a Samuri sword! hgeez:
Old 06-08-2011, 08:28 PM   #7
legend93g2
Improving WHP
legend93g2's Avatar
Thank you Alan!
I know Ive seen pics you you doing this.
Btw, what should i replace the filter with.... wait untill you see the next pics i posthgeez:
It was friendly lol, but the leafs werent....
Old 06-08-2011, 08:30 PM   #8
legend93g2
Improving WHP
legend93g2's Avatar
Default OMG!!!!!!!!!!!!!!!!!!!
Old 06-08-2011, 08:33 PM   #9
Tippey
Pony
Tippey's Avatar
Real Name: Austin
Just be glad you have a filter
if you don't then you get this
Your filter is right infront of there to keep it out of the evaporator coil.
Old 06-08-2011, 08:36 PM   #10
legend93g2
Improving WHP
legend93g2's Avatar
The leaves were on both sides of the filter. I think they are all over the coils as well. An I stuck a vaccum cleaner hose inside and tried to get as much as possible. Got alot but theres definitely still more in there.
a/c, acura, filter, legend
DIY: Fuel Filter GrtOutdoorsAZ Second Generation Legend (1991 - 1995) 1 09-16-2016 06:59 PM
Oil filter? Tippey 1st Gen. Legend General Discussion 47 04-06-2011 08:42 AM
Oil Filter Magnet..anyone used this maxXspeed 2nd Gen. Legend General Discussion 17 07-05-2010 02:16 PM
Oil Filter Nevada Ray 1st Gen. Legend General Discussion 24 06-30-2010 11:09 PM
91 AC Filter? Legend37 2nd Gen. Legend General Discussion 10 06-01-2010 05:29 PM
