Old 06-27-2012, 03:07 PM   #11
Maybe if the tube was clogged, then yeah it wouldn't throw a cel. Bit of the egr itself were clogged, the valve would get stuck and throw a cel.
It's hard to imagine the valve itself being so clogged that it can't close, in part because since the buildup happens a tiny bit at a time, every time the valve opens and closes again will free it up because it hasn't had the time to dry and harden. It's certainly not an impossibility that the buildup is interfering with the operation of the valve, though it's not commonly known to happen. On the other hand, if you own a Legend, and you have not personally had the EGR pipe and manifold cleaned, let's be honest: It's probably clogged, in at least the pipe.
Having no experience with emissions testing though (yay Florida!), I'd not pick out any individual component to say "this is why your X readings are too high". Regardless, it's best to find all contributing factors rather than just the one that puts you over the edge.
Old 06-27-2012, 03:17 PM   #12
my experience on my 91 coupe:
* Replaced the cat and it did virtually nothing - I think general consensus is they do very little.
* Cleaned out the EGR tube and manifold ports - cut NOx in half... still too high
* Replaced both O2 sensors, NOx passed great.
Not related to NOx but another battle on the same year... I also was fighting one of the readings due to the valve stem seals leaking, which completely cleared up once I replaced them.
Old 06-27-2012, 04:22 PM   #13
i;ve seen en stuck plenty of times. also typically the electrial portion wears out thou
Old 06-27-2012, 06:39 PM   #14
Maybe if the tube was clogged, then yeah it wouldn't throw a cel. Bit of the egr itself were clogged, the valve would get stuck and throw a cel. I still don't see the egr alone causing that high of a nox gas value. Egr would probably be the 2nd to last thing I would check.
Chrispy, you gotta read my HG thread again! They always clog uip and the valves nearly never get stuck. No matter how clogged the pipe is, it won't throw a code - that's the flaw in the system. His symptoms are 110% indicative of a clogged EGR system.
Old 06-27-2012, 09:10 PM   #15
Ah, yes, the fatal flaw in the matrix....
And it cant be the extra 10%, cuz thats like, made up and stuff...just sayin
And yeah I should read it again. I need to brush up Im gettin sloppy here
Old 06-27-2012, 10:30 PM   #16
ari_one
MeltingInTheSun
ari_one's Avatar
Didn't have any CEL's for the O2's or anything else.
Old 06-28-2012, 06:06 AM   #17
Ya, my O2 sensors weren't throwing codes either... if you have to pass a sniff test you are going to fail long before the ECU knows the O2 sensors are bad... just one of those things.
Old 06-28-2012, 09:38 AM   #18
sap
ignore the smoke
sap's Avatar
Send a message via AIM to sap
EGR is always suspect in high NOx readings because hydrocarbon combustion in air (in general, not just in engines) produces NOx at high combustion temperatures. EGR is meant to cool the combustion and reduce that, reducing the burden on the cat.
The O2 sensors are important because the cat won't work properly if the mixture isn't right, if the exhaust gas is too lean (too much oxygen left) the cat won't be able to reduce the NOx properly (IIRC ...)
Sig by Cole Austin
RIP Fut RIP l4zy
Old 06-28-2012, 02:27 PM   #19
abathur
abathur is on a distinguished road
A forum member PMed me a shop recommendation in the area and they sounded like they know what they're doing. I think I'll order a pair of O2 sensors, get the EGR system checked at the recommended shop, and then take another shot at passing the emissions test.
Wish me luck. Not going to take it in until Monday, so I'll keep an eye out until then for any other thoughts. Thanks all for your input.
abathur is offline   Reply With Quote
Old 06-29-2012, 07:26 AM   #20
Don't waste your money on o2 sensors if you not getting a code for them. The Legend' o2 sensors are very robust. Clean out the EGR system and you will be golden.
egr, emissions, nox
cleaning 02 sensors failed Conrad 2nd Gen. Legend General Discussion 10 08-21-2011 09:43 PM
Acura legend crash test ( g2 ) Tippey The Water Cooler 12 06-01-2011 11:21 AM
My Legend Failed Me LegendaryAffinity 1st Gen. Legend General Discussion 18 11-26-2010 10:52 PM
Failed state emissions test Tm1 1st Gen. Legend General Discussion 6 10-24-2010 06:51 AM
FAILED emissions due to NO SickSUN71 2nd Gen. Legend General Discussion 9 01-03-2010 06:48 PM
