Old 08-10-2019, 08:41 PM   #1
srqlegend
Default black plastic sleeve/bracket thing for courtesy light switch
Hey all,
Two metal clips: one above and below; shoved thin plastic cards in there and the TCS switch came out. Now trying to get the upper right hand metal clip behind the lower dash panel to let go.
How do you slide out the courtesy light/TCS switch from the plastic box. I broke and replaced one already; is the tab on the top and bottom or on the sides?
Its this:
rectangular black plastic sleeve that serves as the upper left mounting bracket for the lower driver's side dash panel, below the steering wheel? The one that the courtesy/fog light switch slides into? The one that's always broken anytime you find a Legend at the salvage yard?
For pix:
TCS switch box in Lower dash panel
Cheers,
Old 08-12-2019, 05:04 PM   #2
So if I am reading your post correctly you got the TCS swatch out of the plastic sleeve. The two metal clips holding it are on the top and bottom of the switch. As for the upper right hand metal clips once you remove all three 8mm bolts holding the lower dash panel in place you can take the whole lower panel off. There is a clip around the key hole that should pop/slide out fairly easily once all three 8mm bolts are removed. If I understand you correctly the metal clip screws to the back side of the lower dash panel. You can adjust it with the screw.
Old 08-13-2019, 12:22 AM   #3
srqlegend
Default what not to do with cars
Thanks for replying; you are correct, I have the the TCS switch out and all 3 screws holding the lower dash panel. Unfortunately the #$@#$ lower dash panel is still hung up in the right corner above the key. I think whatever that metal clip was; has gotten mangled from me trying pull the panel off.
This all started with a no start condition (probably flaky PGM-FI main relay) some months ago and I let the car sit. At the time everything else was fine.
Now it starts but there is a horrible tapping sound, I only ran it for 30 seconds before I turned it off. Oil level is fine but overdue for a change. I am going to take off the upper timing belt covers to check the belt. Then put in some magic valve juice and let it warm up.
Anything else I should check before running the engine??
Cheers,
FS: LS Fog Light Switch Courtesy/Fog/TCS greenswisher OEM Parts 5 08-15-2018 03:11 PM
WTB: black plastic sleeve/bracket thing for courtesy light switch devolution OEM Parts 7 10-09-2014 02:05 AM
Fog Light/TCS/Courtesy Light switch 08V31-SP0-200H TheLegendOfSpeeD OEM Parts 9 11-12-2012 06:05 AM
91-95 LS sedan fog/courtesy light switch W/O TCS stella OEM Parts 6 09-29-2012 07:44 AM
courtesy/fog/tcs switch panma_jack 2nd Gen. Legend General Discussion 7 10-22-2011 08:24 PM
