Old 07-29-2009, 08:23 AM   #1
bandoni
Hooray! I am useful!
bandoni's Avatar
bandoni has a spectacular aura aboutbandoni has a spectacular aura aboutbandoni has a spectacular aura about
Send a message via AIM to bandoni
Default This Does Not Look Too Great
I am removing my fan relays to see if they work (does anybody know of an easier way of removing these things?!) I removed my condenser fan relay (Condenser fan is the one not working btw)and I discovered this.
here is the inside of the relay, it looks toasted.
now is this burnt charred mess from my relay being bad or is this a common occurrence when removing the relays
Posted from 1885 where I am trapped in the old West and working happily as a blacksmith. Hand delivered by Western Union.
Turbo Miata Build
bandoni is offline   Reply With Quote
Old 07-29-2009, 10:23 AM   #2
Old 07-29-2009, 10:36 AM   #3
ari_one
MeltingInTheSun
ari_one's Avatar
It is not common and should NOT look like that, at least you've found your problem. The hard part is to figure out is whether the relay caused the problem or the relay took the hit
PS they are a bit of a pain to remove, you have to bend them back and forth (side to side) while pulling on them if you don't have something to pry up on the tabs.
Old 07-29-2009, 10:58 AM   #4
alittlethin
alittlethin's Avatar
alittlethin will become famous soon enough
You should go to the junkyard and get a new fuse box or Ari probably has three of them in his garage from his never ending part-out.
"Where the F.. is the, "SWEET SPOT !!??",... I can't find it??
Come on man, don't take it so serious. It takes a lot of comitment and pride to throw money into something that will never yield a 16th back.
~Dv8
alittlethin is offline   Reply With Quote
Old 07-29-2009, 12:21 PM   #5
bandoni
bandoni's Avatar
I know what you mean, I am thinking that the relay is the source of the short. That relay was so hard to remove it was literally fused into the relay box!!
Turbo Miata Build
Old 07-30-2009, 04:52 PM   #6
gibbsrcing
gibbsrcing is on a distinguished road
Send a message via Yahoo to gibbsrcing
wow. definitely found your issue. even if it was just the relay i would suggest putting a new box in also that one looks like it got HOT!!! good luck
gibbsrcing is offline   Reply With Quote
Old 07-30-2009, 05:10 PM   #7
bandoni
bandoni's Avatar
well I put a new relay in and it is all back to normal. I looked into replacing that box and it has the whole rest of the engine wiring harness attached to it.
Turbo Miata Build
Old 07-30-2009, 06:58 PM   #8
alittlethin
I thought there were detachable plugs in the ass end of it I guess I'm wrong...
~Dv8
Old 07-30-2009, 11:19 PM   #9
ari_one
MeltingInTheSun
ari_one's Avatar
The main fuse box has removable connectors but the small boxes are direct wired to the main harness that goes from inside fuse box to under hood fuse box, to lights, small fuse boxes and around to the ABS assy and finally to the ECU!
Old 07-30-2009, 11:22 PM   #10
the most you can do if it becomes a problem is dremel out the old connector/plug in the fuse box, and rewire the 4 wires that where connected there into a new relay. :/
FS: GREAT Audio NEEDS a new home GreekPower Non-OEM Parts 1 07-22-2009 03:15 PM
First Car videos not that great Roger Second Gen Legend Gallery -- 1991 - 1995 10 07-08-2009 03:11 AM
Great job bandoni Feedback and Requests 11 06-10-2009 03:55 PM
Great New Mod! Improves G2 *and* G1 Legends UNCLEgend 2nd Gen. Legend General Discussion 36 06-09-2009 11:11 AM
Great idea to pay off debts! Goatman The Water Cooler 1 06-05-2009 01:03 AM
