Old 06-27-2009, 03:09 PM   #1
Roger
Roger's Avatar
Default A touch of Red
I thought I could use a change so I picked red! Easy as spray, bake, and serve!! I think it looks pretty good. Probably do the coil packs next.
EDIT
DIY
1. Get some High Temp engine paint for your local parts store.
2.) prepare your surface with a high grit sandpaper say 200
3.) wash surface with soap and water to remove all dirt
3.) After dry, lay down a few coats of automotive primer (let dry 10 min in between)
4.) Start in with a few light coats of your high temp engine paint (10 min between coats)
5.) After applying 3-4 good coats I like to lay down a thick coat at the end to bring out a nice even gloss finish.
6.) Let dry for 2-3 minutes then pop it in the oven at 200-230 for about 35 minutes (Set timer!!).
7.) After you take them out let them cool off till you can handle them.
8.) You are DONE!! the paint is totally cured you can touch it all you want it will be rock hard!
9.) Install and enjoy!
I finished my Coils today
Old 06-27-2009, 03:13 PM   #2
Why did you bake?
Old 06-27-2009, 03:22 PM   #3
daveCFPrez
54102-SP0-A00
daveCFPrez's Avatar
Real Name: uh, Dave
I'm not a big fan of red, but I gotta say it matches with your battery ! looks well balanced
dave
signature after Dannie
Old 06-27-2009, 03:28 PM   #4
SuperLegend91
Admit the obsession
SuperLegend91's Avatar
Real Name: Tony B
SuperLegend91 will become famous soon enough
Send a message via Yahoo to SuperLegend91
I was thinking the same thing. usually red looks a touch ricey in the engine bay, but in this case I like it. I thought about doing this and dismissed the thought but this makes me rethink doing this myself
If it wasn't for physics and law enforcement, I would be unstoppable!
<a href=http://i161.photobucket.com/albums/t235/JesterTypeR/legend%20shoot%207-21-08/P1000437-1-1.jpg target=_blank>http://i161.photobucket.com/albums/t...000437-1-1.jpg</a>
R.I.P Fut -one-
SuperLegend91 is offline   Reply With Quote
Old 06-27-2009, 03:37 PM   #5
Roger
Roger's Avatar
you bake to cure the paint, that way its not effected by oils and its rock hard just like if you had it professionally painted with a hardening additive
Old 06-27-2009, 03:45 PM   #6
Oh okay. Look's good, did you use adhesion promoter?
Old 06-27-2009, 04:03 PM   #7
Nice job Roger. Looks really nice. What'd you use for paint?
Old 06-27-2009, 04:03 PM   #8
what do i need to paint does?
Old 06-27-2009, 06:50 PM   #9
Adhesion promoter or paint made for platic.
Old 06-27-2009, 09:57 PM   #10
WhyteLegend
3.52..
WhyteLegend's Avatar
WhyteLegend is on a distinguished road
Nice .. why did y tape out the text ..
KA7 3.5 TII 6spd LSD + more,95 KA8 3.5 LS , KB1 H&R Springs, 09 Rear Sway Bar, CAI, 20" Giovanna
http://i33.photobucket.com/albums/d88/mark2000jm/AC-RL1.jpg
WhyteLegend is offline   Reply With Quote
