Old 06-19-2009, 12:52 AM   #1
Default A/T service done... DIY (G1 specific) coming up!
Now I know why most G1 owners do not bother to writing a "DIY" procedures when performing this task; well, NOT me ...draining/filling the tranny is the easy part, but removing them solenoids on the other hand are a handful, let alone documenting every single part that needs to be remove.
I'm gonna give it my best; to lay this one out step by step, with detailed image attachments, in hoping to help explain the process as clearly as possible.
And the lock-up/shift solenoid function test is self explanatory, so I just leave that one alone... but again if needed, I can attach a brief instructions on this as well.
Also got my "battery service" done... pretty straight forward, but can be DIY if needed.
After some elbow grease, these babies look like new
Old 06-19-2009, 08:33 AM   #2
This type of service is NOT too difficult; scale from one to ten, oh I'd say a five'r... but the whole process was very time consuming though. So just bear with me, as I edit and add text on some of the photos ...well worth it in the end, I would think!
Here's yet another proof that regular ATF change will help extend the life of your tranny
Not so much; as far as fluid restriction is concern...
Lock-Up Solenoid filter screen; before cleaning... after cleaning!
Shift solenoid filter screen; before cleaning... after cleaning!
Old 06-19-2009, 04:05 PM   #3
Mikeo
1989 Acura Legend
Mikeo's Avatar
Real Name: Mike
so just take them off and take out the screens and rings to clean. Than just put back on or what?
Old 06-19-2009, 05:56 PM   #4
Just wait young jedi, there is more to it before you put everything back together.
Old 06-19-2009, 10:06 PM   #5
In a nut shell, you are correct Mike ...but consider this though!
Just to get to the solenoids (in my case), the following had to be removed
-front driver side tire
-splash guards (if you still have them)
-battery + holding tray
-air box (bottom half is very tricky)
-intake air duct (it's a bitch)
-disconnecting solenoid connectors (very brittle) + mounting brackets
-mounting brackets; solenoids harness, ATF feed and return cooling lines
-ground cable to engine chasis
Even then with ALL these out of the way, they (solenoids) are a wee bit challenging to remove from the tranny.
Once removed, there is the solenoid cleaning phase.
After a complete cleaning, there is the solenoid testing phase.
And then... you'd have to put everything back together... very time consuming I know, but well worth it!!!
3 hours total downtime; ONLY because I was documenting every steps of the way
Old 06-19-2009, 10:48 PM   #6
Mikeo
1989 Acura Legend
Mikeo's Avatar
Real Name: Mike
i dont know about that lol i got the CAI so its a little easyer But everything else oh boy lol thats a weekend job lol. Maybe you can show me at the meet and greet.
Old 06-19-2009, 10:57 PM   #7
Goatman
Head Ninja
Goatman is on a distinguished road
Send a message via AIM to Goatman Send a message via MSN to Goatman
Why the heck did you need to remove the tire? I remove the air box and hose, MAYBE the battery, and all you gotta do is work around the coolant hoses.
Goatman is offline   Reply With Quote
Old 06-19-2009, 10:58 PM   #8
Mikeo
1989 Acura Legend
Mikeo's Avatar
Real Name: Mike
ya? how do you test them?
Old 06-19-2009, 11:09 PM   #9
Goatman
Head Ninja
wire up the 12volt, and ground the outside. If it clicks, it's switching. If it doesn't, it's stuck, and needs more WD40, carb cleaner, brake cleaner, whatever you use.
Old 06-19-2009, 11:13 PM   #10
Mikeo
1989 Acura Legend
Mikeo's Avatar
Real Name: Mike
Shit that sounds easy whats the hard part cause me and workin on the engine freaks me out some times
