Old 08-16-2012, 08:51 AM   #1
jutycus
Real Name: Desmond
jutycus is on a distinguished road
Default Off topic....Honda Accord
I don't feel like registering on a Honda Accord forum, so I want to see if any of you know what, if any, accord engines are a direct replacement for an F22A6(other than F22A6). The F22A6 is very hard to find. Not trying to do a swap, I need a direct replacement.
jutycus is offline   Reply With Quote
Old 08-16-2012, 09:25 AM   #2
this is in the wrong section
im pretty sure you can browse the accord forums without registering but there are a few cb7 owners here that can probably help you out
Old 08-16-2012, 12:27 PM   #3
0S1R1S
0S1R1S is on a distinguished road
Just a guess, but wouldn't an H22A motor and tranny swap in direct with a reflash? Or you might need to swap the ECU and harness.
Otherwise, I think you'd have to stick with the F series 2.2 liters motors.
0S1R1S is offline   Reply With Quote
Old 08-16-2012, 12:38 PM   #4
F23 should be a direct swap.
iirc H22 will still require mounts and other stuff to make it work.
Old 08-16-2012, 02:18 PM   #5
jutycus
Real Name: Desmond
Sorry about it being in the wrong place......
I need an engine that will drop right in with no modifications. It's a 92 Accord EX. The current engine that's in it is the f22a6. The accords have so many engine variations, it's confusing. The reason I'm replacing the motor is because the cam shaft seized on it breaking the timing belt. When I was changing the timing belt, that's when I noticed the cam shaft wouldn't move for me to set the timing. I'm not sure what caused it to sieze, so I didn't want to take a chance with replacing the head(because the initial problem could still be there).
Old 08-16-2012, 05:15 PM   #6
Gearhead
Yup, That's Me
Real Name: Ian
Gearhead is on a distinguished road
F22A4 is a direct drop in, only reason I know is because I went through 3 f22a* motor before going to an H22A
Originally Posted by ManOfBusiness View Post
For $500 bucks I better cum buckets just from listening to porn.
Gearhead is offline   Reply With Quote
Old 08-16-2012, 07:17 PM   #7
thegrouch
simple
Real Name: Garrett
thegrouch will become famous soon enough
f22a4 and f22a1 will need their respective ecu's and (i think) wire harnesses. At least the ecu definitely. f22a6 has IABs which is not on the other two motors. However, any f22 or f23 will mount to the stock transmission, as well as H motors.
thegrouch is offline   Reply With Quote
Old 08-16-2012, 08:08 PM   #8
jutycus
Real Name: Desmond
Don't mean to sound like an idiot, but what is IAB's?
So, basically, I can get an f22a4 or a1 as long as I have an ECU to match?
Honda Accord OEM Radio diontree1 2nd Gen. Legend General Discussion 1 06-24-2012 02:30 PM
1,000,000 Mile Honda Accord sam o nela The Water Cooler 7 10-25-2011 02:42 PM
94-97 honda accord radiator GreekPower 2nd Gen. Legend General Discussion 13 06-22-2011 12:22 PM
FS Honda Accord wtf 91RosewoodBrown The Water Cooler 11 08-03-2010 07:12 AM
