Old 11-22-2019, 06:46 AM   #1
Tim J
Tim J is on a distinguished road
Default 89 Legend Coupe Rear Right Window
The rear right window on my 89 coupe is slipping down into the rolled down position without powering down. Does anyone have an idea of what might be the root cause of this problem? How would it be repaired? Thanks!
Tim J is offline   Reply With Quote
Old 11-22-2019, 01:23 PM   #2
Hi Tim,
Not having seen the window mechanism, I can only speculate.
In my '90 Sedan the sunroof utilizes a gear that engages a toothed belt. At the forward limit of travel the belt has a broken tooth. It closes enough, but not tightly.
If your window utilizes a similar mechanism then a broken tooth at the upper limit of travel might allow it to slip. You can test this theory by rolling it not quite all the way up and then seeing if it still slips back down.
Old 11-22-2019, 05:52 PM   #3
Tim J
Thanks for that suggestion. I will test it out and let you know my findings. Thanks!
[IMG] code is Off
WTB: WTB: Gen 1 Coupe Rear Power Window Regulators Honda600King OEM Parts 0 09-01-2015 10:02 AM
WTB: Rear window frame- driver side - Legend coupe G1 Fukurou OEM Parts 0 05-18-2015 12:27 AM
Q: Coupe Rear Window Regulators paulo57509 1st Gen. Legend General Discussion 0 12-27-2009 12:38 AM
Coupe Rear Window Switches !!! Travis_Gib0 1st Gen. Legend General Discussion 10 10-11-2009 06:58 PM
Legend Coupe Rear Window all the way down, mod? Lsportline43 2nd Gen. Legend General Discussion 22 09-29-2009 09:00 PM
