Old 12-13-2009, 07:29 AM   #1
Exclamation Quick questions thread
Hi,
I think this might be help full for new members and seasoned members alike to have a thread where you can post quick questions that don't need there own topic to keep the forum nice and clean and keep the reposts down.
So if some one has a small question then can post it up here.
Old 12-13-2009, 07:35 AM   #2
OLDSKOOLACURA
legend love
OLDSKOOLACURA's Avatar
good idea.
i'm doing a mesh grill today and i'm going to paint the chrome black.
what are the steps to paint the chrome?
sand, paint, wet sand, clear coat, then wet sand again???
i sent this to roger but i don't know when he will be up.
Old 12-13-2009, 07:38 AM   #3
Sand, Degrease, prime, if needed wet sand, degrease, color then clear.
Make sure your primer and paint are the correct type.
Let it dry nicely, don't rush, don't panic, nice and easy build up layers evenly. you should be fine.
Old 12-13-2009, 07:55 AM   #4
OLDSKOOLACURA
legend love
thanks
Old 12-13-2009, 11:05 PM   #5
Igor_ka8
KA8 6MT
Igor_ka8 is on a distinguished road
I have a Quick question.
How do i remove the metal things from where the clips of the chrome molding sat
As you can see theres 2 of them
The Restoration
After Paint Gallery
<<<Legend KA8>>>
Igor_ka8 is offline   Reply With Quote
Old 12-13-2009, 11:20 PM   #6
i have a question...
how exactly do the valve stem seals in our engines (3.2) look like??
Old 12-13-2009, 11:32 PM   #7
canucks
canucks is on a distinguished road
imo you should replace that piece instead of removing those or paint it the trim to match
Quick Question
D3 is for stop and go traffic and D4 is for normal and highway driving. What am I supposed to use for city driving. I don't like to go into D4 unless im on the highway and it would be wrong to be driving in overdrive all the time right. What do you drive in?
canucks is offline   Reply With Quote
Old 12-13-2009, 11:57 PM   #8
Originally Posted by canucks View Post
Quick Question
Neither way is right or wrong. It's all about your opinion and "strategy" I guess. I always drive in D4 unless I need to downshift which is rare because usually I just floor it to downshift. I just like to drive in the highest gear to cruise the most. In a way it's like how in a MT you usually like to cruise in a higher gear to save gas. Maybe sometime I'll compare gas mileage driving in the city in D3 vs D4. I'd would say that the advantages of driving in D4 really show above 40mph. If you're driving below that speed the differences in gas mileage between the two would be pretty small, I think.
Old 12-14-2009, 12:00 AM   #9
Igor_ka8
KA8 6MT
Yea i need to remove inorder to put new ones. Well i dont know how to remove them. And when i go to the junk yard how am i supposed to remove them without breaking them. Because at the dealer they sell all the clips, and it costs way too much. if anyone could please help, i cant solve this damn problem for a while.
The Restoration
After Paint Gallery
<<<Legend KA8>>>
Old 12-14-2009, 12:02 AM   #10
NorCaLegend
Straight OEM
NorCaLegend's Avatar
NorCaLegend is on a distinguished road
Send a message via AIM to NorCaLegend
They're the little circular things sitting in the red plate. Sorry I don't have better pictures of them, it never occured to me to take pictures of the seals when I did this job. In the lower right corner of the head, where the valve and valve spring are removed, you can see the opening that the valve stem fits into. The seal fits right over that. When you replace the seals, make sure you coat them lightly with a little bit of CLEAN motor oil (preferably the oil you'll be using in the car) so they don't get damaged when you fit the stem through them or when you first start the car.
Edit: Coat the valve stem with oil too.
- NorCaLegend -
1991 L(S) Type I(I) coupe
Build thread: http://forums.acuralegend.org/norcal....html?p=188337
NorCaLegend is offline   Reply With Quote
My 1st Thread for ALL MY Questions from now on here... One6DSwifflY 2nd Gen. Legend General Discussion 98 04-10-2018 07:30 PM
Quick Question Trs031 Second Gen Legend Gallery -- 1991 - 1995 3 08-27-2009 11:17 PM
Quick question Ablest31 2nd Gen. Legend General Discussion 8 08-18-2009 09:18 AM
Quick questions to you tilt mod legend pepz BklynSoulja 2nd Gen. Legend General Discussion 6 08-14-2009 06:43 PM
