Old 12-31-2012, 02:27 PM   #31
stevieray
Old Ass Moderator
stevieray's Avatar
stevieray will become famous soon enough
Sticky worthy. Consider it done.
R.I.P. Fut
stevieray is offline   Reply With Quote
Old 01-15-2013, 12:02 PM   #32
devolution
crazy diamond
devolution's Avatar
Real Name: Rollin
devolution will become famous soon enough
about that U-joint...is there anything in there that needs greased as part of regular maintenance? i did not see any old grease residue when i was cleaning mine but i know some U-joints do need to be lubed regularly.
devolution is offline   Reply With Quote
Old 01-16-2013, 09:52 AM   #33
It's a sealed, non serviceable unit.
Old 01-17-2013, 01:58 PM   #34
TRINIGUY
TRINIGUY's Avatar
TRINIGUY is on a distinguished road
I just rebuilt my rack with a new seal kit and paid special attention to installing that bolt from the shaft to the ujoint.it's very easy to strip that bolt.I took the advice and used a new one. My steering is nice n smooth but a little firm.lovin it.
watcha lookin at foo
TRINIGUY is offline   Reply With Quote
Old 01-17-2013, 02:37 PM   #35
MXHalofan
Type O Master
MXHalofan's Avatar
You can just thread in a longer 10mm bolt if the threads strip like Soloist was asking. Then put a nut on the end. I had the right bolt in my spare bolts bin. The only forces on this joint is the torsion of the splined collar end so there's no need to worry about the splines stipping.
I bought a legend and drove home that had a bad 6mt flywheel. Looked under there and the column was barely attached to the splines on the pinion. Way dangerous. That column slides in and out in case of an accident and it must have been bumped up during the previous clutch job, so make sure it's all the way down and fully engaged on the splines when reinstalling the rack during replacement or a clutch job.
91 Coupe LS black on black
GS wheels
MXHalofan is offline   Reply With Quote
Old 01-17-2013, 03:45 PM   #36
Absolutely terrible, bad advice. If it strips, replace the joint! Can you please delete so no one reads it.
Thanks
Matt
Old 01-17-2013, 07:35 PM   #37
MXHalofan
Type O Master
MXHalofan's Avatar
LOL at you. You're the one with terrible advice.
GS wheels
Old 01-18-2013, 01:52 PM   #38
bluesongz
Doesn't Post Much
bluesongz's Avatar
Real Name: Thomas
bluesongz is on a distinguished road
This is what I did. Installed a through-bolt then a nylock threaded nut. I guess worst case is that it breaks while I am doing 90 down the freeway and I end up with interesting life experience.
bluesongz is offline   Reply With Quote
Old 01-18-2013, 03:11 PM   #39
Please explain how running a smaller, less stronger bolt that you found in your toolbox through a safety related part is good advice.
Old 01-18-2013, 03:21 PM   #40
Glad you live on the other side of the country.
300$ Engine Swaps --- 4hrs (usually) mad_legend The Water Cooler 25 03-21-2013 07:30 AM
steering rack / rack/pinion for 1st gen rl music2bmurderedby OEM Parts 1 10-25-2009 05:37 AM
HELP!! my steering rack!! Roger 2nd Gen. Legend General Discussion 17 10-23-2009 11:02 PM
Steering Rack DIY? Roger 2nd Gen. Legend General Discussion 8 10-20-2009 02:11 PM
DIY: Steering Rack Removal sam o nela First Generation Legend (1986 - 1990) 0 06-03-2009 01:26 PM
