Old 11-28-2009, 07:59 PM   #21
Roger
Roger's Avatar
Originally Posted by soloist View Post
^ I like that idea. What about the bolt on the rack? Couldn't you use a threaded bolt that goes all the way through so you could put a nut on the end, or am I just way off here (I admit I don't know that much about rack and pinion system other than the basics of how they operate).
Thats exactly what I said above!!! I actually did do this until I bought a new bolt after I stripped mine. I think it should actually be stronger
Old 11-28-2009, 08:34 PM   #22
man, i didn't read this whole thread, but i'd listen to sr5guys advice, i had my joint come apart after i did a rack job, and also it came out at a low speed. i felt it skip trying to turn at a highspeed, got off the highway, and it poped out completly at a low speed. scary.
Old 11-30-2009, 01:33 AM   #23
scorchingeng
Heatshield Bolt Hate
scorchingeng's Avatar
scorchingeng is on a distinguished road
Well, inspected mine at the splines were fine.
I sad f*** the world and drilled through that shit. Installed a stainless bolt, lock washer, and nut. Locktited the whole mess. Wish me luck.
Respect the Rice
scorchingeng is offline   Reply With Quote
Old 11-30-2009, 06:15 AM   #24
You never cease to amaze me....excellent write up
Old 09-01-2011, 11:25 AM   #25
Vic Cardenas
Vic Cardenas's Avatar
Bump for some good, relevant info! I'm about to replace the rack on my car. Took out the rack on my parts car and boy was that bolt rusty. I suspect the bolt on my car won't be so rusty but it still is peace of mind for 50 cents.
AutoAlchemist.com
Old 09-01-2011, 11:37 AM   #26
Admiral Vorian
Elite Member
Admiral Vorian's Avatar
Admiral Vorian is on a distinguished road
this is serious business. on my sedan this broke while I was parallel parking - not a minute after getting off the freeway!
Admiral Vorian is offline   Reply With Quote
Old 09-01-2011, 12:14 PM   #27
Good call.
I always used a 1/4 drive hand wrench to put that (and various other) bolts in. You have to have the knuckle in just the right spot and you need to feel that everything in progressing easily. The air wrench spells failure on this one.
I rebuilt many legend racks and never had one knuckle fall ill on me, I think largely because I always used a light wrench until that final "tweak" to torque it.
Old 09-01-2011, 12:15 PM   #28
xpressive
Seattleite
xpressive is on a distinguished road
What are symptoms of this issue? I am noticing that when driving, I can wiggle the steering wheel left and right a bit without getting response. Should I get looking into tightening that bolt?
1994 Acura Legend LS 3.5 - 284k SOLD. [02/21/2013]
RIP Fut.. Never forgotten.
xpressive is offline   Reply With Quote
Old 09-01-2011, 01:13 PM   #29
Vic Cardenas
It could be. I have the same problem but I think it's due to actual parts in the rack and pinion going out. As per this thread...
http://forums.acuralegend.org/light-...1.html?t=20531
If I were you, I'd get under your car and look at that joint.
AutoAlchemist.com
Old 11-16-2012, 04:31 PM   #30
Bump for good info!
300$ Engine Swaps --- 4hrs (usually) mad_legend The Water Cooler 25 03-21-2013 07:30 AM
steering rack / rack/pinion for 1st gen rl music2bmurderedby OEM Parts 1 10-25-2009 05:37 AM
HELP!! my steering rack!! Roger 2nd Gen. Legend General Discussion 17 10-23-2009 11:02 PM
Steering Rack DIY? Roger 2nd Gen. Legend General Discussion 8 10-20-2009 02:11 PM
DIY: Steering Rack Removal sam o nela First Generation Legend (1986 - 1990) 0 06-03-2009 01:26 PM
