Old 09-05-2019, 10:02 AM   #1
byalegend
byalegend's Avatar
byalegend is on a distinguished road
Default Exhaust Gasket Compatibility
It looks like the starter on my 1999 Acura RL is dying, so I'm looking at replacing it this weekend. I have a stash of Legend parts, including the cat converter-to-y-pipe exhaust gasket (18229-SP0-003). Is this gasket compatible with the RL (18229-SZ5-003)? Dealer wants $56 �� The other exhaust gaskets and nuts share the same part numbers.
My 1999 Acura RL "Build": http://forums.acuralegend.org/showthread.php?t=34510
byalegend is offline   Reply With Quote
Old 09-06-2019, 07:27 AM   #2
you don't need to remove the exhaust at all to do the starter. the bolt is very excessible with the exhaust in place. you'll need to pop the axle out of the oil pan, you don't need to remove it from the knuckle. i usually undo the upper ball joint and pull the axle out of the oil pan intermediate shaft, and let it hang out to the side, pull starter out. done.
Old 09-06-2019, 01:46 PM   #3
byalegend
byalegend's Avatar
Hmm, ok. If I have to remove starter, I'll give that a try. Hopefully, it's just as simple on the RL. I noticed the service manual procedures for replacing the starter on the RL have quite a few more steps than those for the Legend.
Thanks.
Radio compatibility on a G1 AcuraLegend55k1990 1st Gen. Legend General Discussion 1 01-15-2015 08:01 AM
exhaust manifold gasket keeps going gravesg 2nd Gen. Legend General Discussion 4 09-09-2014 02:16 PM
WTB: Exhaust gasket for stromung B-pipe Shamar_Legendary OEM Parts 4 07-31-2013 02:30 PM
suspension compatibility supple007 2nd Gen. Legend Performance Enhancements 4 04-25-2013 11:21 AM
Parts compatibility Peabodyn 1st Gen. Legend General Discussion 2 03-11-2010 11:31 AM
