Old 03-20-2019, 01:48 PM   #1
IamPlan_B
Default Battery light coming on and off
When starting , battery light comes on and off when I accelerate and back on when off pedal in park. Also does this sometimes when driving.
I've replaced the alternator about a year or so from auto zone and battery is also replaced due to door lock solenoids draining previous battery at night.
Removed door lock fuse, so that's no longer issue. Also abs light comes on and then off at same time as battery light goes off at start up but then won't come back on.
I don't see or feel any difference in performance or slowing down on electrical components I.e, power windows or wipers
Old 03-22-2019, 04:26 AM   #2
tstint16
tstint16's Avatar
tstint16 is on a distinguished road
Double check the wiring going to the starter it could come loose making just enough contact to start the car also, have you done a voltage test on your system. I would hate to say its your alt thats bad but it could be even though you replaced it a year ago.
tstint16 is offline   Reply With Quote
Old 03-22-2019, 09:22 AM   #3
IamPlan_B
I will check all wiring connections and have alt tested.
Old 03-23-2019, 10:38 AM   #4
alittlethin
alittlethin's Avatar
alittlethin will become famous soon enough
Your brushes on your alternator are probably going bad. I'd take a look at replacing it...it's a pain in the ass to get that fucker out...best of luck.
"Where the F.. is the, "SWEET SPOT !!??",... I can't find it??
Come on man, don't take it so serious. It takes a lot of comitment and pride to throw money into something that will never yield a 16th back.
~Dv8
alittlethin is offline   Reply With Quote
Old 03-23-2019, 01:34 PM   #5
IamPlan_B
But that alternator isn't even that old, and the one I replaced was the original
battery light stays on--battery fully charged, car won't start. blackeagle229 2nd Gen. Legend General Discussion 8 01-17-2012 03:01 PM
Battery light Maximus 2nd Gen. Legend General Discussion 2 07-23-2011 03:05 PM
Alternator :Battery light, blinking tcs&abs light robertstrendell 2nd Gen. Legend General Discussion 3 12-14-2010 02:46 PM
TCS and ABS light coming on. acura_boi95 2nd Gen. Legend General Discussion 2 12-09-2010 10:15 PM
need help please =/ battery light on BklynSoulja 2nd Gen. Legend General Discussion 12 08-13-2009 07:29 AM
