Old 03-22-2019, 09:31 AM   #21
IamPlan_B
No abs light, but having low brake pedal, so I have bled all four wheels and still have low pedal, do I need to bleed the abs unit? How can I do without the bleeder wrench if that's possible. I don't want to stop now, after I already repaired/replaced whole front end, new brakes and tires, replaced abs unit.
Don't want to drive it until its done, and that's the last issue - the low pedal.
That was like that before accident as well, maybe it could be master brake cylinder, which i replaced with OEM about ten years ago
Old 03-22-2019, 07:53 PM   #22
I don't think the abs can cause a low pedal.
Bad Master Cylinder is the most likely culprit.
Old 03-23-2019, 08:55 AM   #23
IamPlan_B
I appreciate all your input, thanks. I'm gonna order a new one from acura if still available.
Old 03-28-2019, 02:08 PM   #24
IamPlan_B
Replaced booster, and new master cylinder. And still no brake pedal pressure when engine on.
Also in fuse box, I am still not getting any power going to abs motor fuse (7.5) at any time? Could this be any way connected to my issue?
WTB: ABS Modulator jose3030 OEM Parts 2 07-20-2017 08:25 PM
ABS Modulator Leak tenk otomubay 2nd Gen. Legend General Discussion 2 01-21-2014 03:44 AM
ABS modulator rebuild? cakes 1st Gen. Legend General Discussion 5 08-18-2012 08:24 AM
FS: Remanufactured OEM Legend ABS Modulator Olikado OEM Parts 6 02-29-2012 02:12 AM
