Old 03-15-2019, 08:27 AM   #11
IamPlan_B
Yep, pump/modulator is defective.
I tried connecting a jumper wire on terminal 1:& 2 where abs relay is located, and I can hear the motor run. But still not getting any power going thru alb1 fuse
Old 03-15-2019, 08:31 AM   #12
IamPlan_B
How diffcult is it to replace this pump/modulator?
Old 03-15-2019, 02:39 PM   #13
While you were running the pump, did the sound change to indicate increasing pressure?
Have you opened the bleeder screw to see if there is any pressure in the system? (Warning: be very careful when opening the bleeder screw, especially if you aren't using the Bleeder T-Wrench, as there may be very high pressure.)
Old 03-16-2019, 03:16 AM   #14
IamPlan_B
I just jumped to see if motor runs thats all. I didn't try checking because I assumed without that wrench it would be too hard and possibly get brake fluid everywhere
Old 03-16-2019, 08:37 AM   #15
IamPlan_B
Where can I get a bleeder twrench
Old 03-18-2019, 03:57 AM   #16
I got mine from Honda. Don't know if they still sell them.
You could also try activating the solenoids. If there is pressure and if the solenoids will activate then the fluid in the reservoir will rise. There's a thread somewhere on the forum that shows how to activate the solenoids.
Just to double check, did you notice in the link in post#9 that you can page Next to see the rest of the troubleshooting guide?
Old 03-18-2019, 10:57 AM   #17
IamPlan_B
Yeah, I saw that link.
I went and picked up a used modulator and pump that I removed from a type 2 coupe yesterday for 90 bucks at the local pick a part yard. Going to swap them out and hopefully be done with it.
Got the car fixed, just need this done to her on the road again
Old 03-18-2019, 06:48 PM   #18
Did you test the new pump to see if the motor builds pressure and activates the pressure switch? If not, you are probably just wasting your time as 80%. Of the time junk yard units are no good.
Old 03-19-2019, 11:58 AM   #19
IamPlan_B
I haven't test yet, the car has just came in running and driving but with BHG, so I'm just gonna hope for the best. Maybe I can make one complete working unit out of two setups
Old 03-19-2019, 07:34 PM   #20
IamPlan_B
Guess i got a lucky one of those 20%, as I install replacement unit and fill with new brake fluid and no more abs light on start up .
WTB: ABS Modulator jose3030 OEM Parts 2 07-20-2017 08:25 PM
ABS Modulator Leak tenk otomubay 2nd Gen. Legend General Discussion 2 01-21-2014 03:44 AM
ABS modulator rebuild? cakes 1st Gen. Legend General Discussion 5 08-18-2012 08:24 AM
FS: Remanufactured OEM Legend ABS Modulator Olikado OEM Parts 6 02-29-2012 02:12 AM
