Old 01-12-2018, 09:23 AM   #1
vayankee
vayankee is on a distinguished road
Default Parts needed for timing belt and water pump replacement
Has anyone posted a list of parts needed for these jobs? I tried a search but did not see such a list.
Thanks.
vayankee is offline   Reply With Quote
Old 01-12-2018, 11:36 AM   #2
lanzarlaluna
Legend Grasshopper
Real Name: Matt
lanzarlaluna is on a distinguished road
Thanks.
Obviously the timing belt, water pump, and water pump gasket. There is also the gasket on top of the water pump. Other optional parts while you're in there would be the valve cover gaskets, spark plug tube seals, lower tube seals, rear cam plugs, front cam seals, and all the little water lines in front of the engine. I would consider replacing all the accessory belts at the same time too.
Sent from my SM-G930P using Tapatalk
lanzarlaluna is offline   Reply With Quote
Old 01-12-2018, 04:18 PM   #3
vayankee
Thanks for your post! I had not thought of those rubber hoses for replacement.
I have to apologize also. I forgot to mention that there's an oil leak coming from the lower timing belt cover. Would that be either the cam shaft seals or crankshaft seal, or something else?
Thanks.
Old 01-13-2018, 11:19 AM   #4
lanzarlaluna
Legend Grasshopper
Real Name: Matt
Thanks.
Could be the crank seal or even the oil cooler.
Old 01-13-2018, 12:00 PM   #5
vayankee
Great-thanks!
Old 11-01-2018, 12:42 AM   #6
BluePhoeniX
BluePhoeniX is on a distinguished road
So it doesn't appear that we can get dealer or AISIN water pumps anymore. What brand of water pump does everyone use now?? Are those Contitech Pro Plus kits a solid choice for belts and pumps?? They even come with cam seals and a lifetime guarantee (based on manufacturers suggested maintenance interval -- 90,000 miles). Thanks!!
BluePhoeniX is offline   Reply With Quote
Old 11-01-2018, 04:00 PM   #7
You Should also change the timing belt tensioner.
Old 09-21-2019, 11:32 PM   #8
srqlegend
Default wholesaler closeout timing belt!
I couldn't resist the RockAuto closeout BECK/ARNLEY 0260302 timing belt for under $10.00; the box said Made in USA.
I would have ordered the CONTINENTAL 40193 but I got one of those Prop. 65 warnings about vendor did not supply information. Stupid vendors and California for not figuring this out; they had many years to do so.
PS: I know this is an old thread but its timing belt related.
WTB: OEM timing belt, water pump & tensioner stella OEM Parts 2 02-14-2014 12:44 AM
FS: New OEM Timing Belt & Water Pump (2nd gen) wadd3456 OEM Parts 0 06-09-2011 06:10 AM
87 legend: timing belt/water pump replacement Fred Clark 1st Gen. Legend General Discussion 6 11-10-2010 08:36 AM
Timing Belt/Water Pump DIY - no pics? wendigo 1st Gen. Legend General Discussion 10 10-22-2009 02:44 PM
Water Pump/Timing Belt Parts Poochmike 2nd Gen. Legend General Discussion 4 06-06-2009 09:59 PM
